#20
please ... i forget the recovery ker for my hard disk ,,,, please help meeee
Hello Shadilami, and welcome to Seven Forums.
Without the recovery key, you're pretty much out of luck on being able to access the HDD without taking the HDD to a expert data recovery shop.
If you did step 6, you could use it to regain access to the HDD.
yes i did step 6 .. but i lose the recovery key .... please hellp me ... all my file on HDD
I'm sorry to hear that. Without the recovery key or password to access or unlock the removable drive, you're out of luck. You might be able to recover them by having a professional data recovery service attempt to, but it most likely will not be cheap if they are able to.
The HDD could be formatted to be able to use it again, but you will lose what is on it.
i am not able to see "turn on bitlocker" when right clicking on any partition on any hard drive or on external usb thumb drive.
please find below screenshots and advise.
my system is dell optiplex 755 with tpm 1.2 and windows 7 ultimate
thanks
Formated with fat in above snapshots
now formated with ntfs but still same.
also why is it not shown for other partitions ?
i have 2 hard drives and it is enable bit locker is not shown in right click context menu for any of them.
Hmm, I'm not sure why you don't see the BitLocker context menus.
You might run a sfc /scannow command to see if you may have any corrupted system files responsible.
sfc scannow was run yesterday but no violation was found.
what services needs to be started for bitlocker ? there are two containing bitlocker and they were set to disable i set them to automatic and started them.
i had followed some tweaking guide floating on net long time ago. that only required changes in services ..
