YEEEEEHAAAAAA love my new info screen hehe tyvm Shawn you are awesome !!
is it possible to automate the process so you can send a .exe for example and it will automatically collect the infomation it needs without manual interaction?
Hello Rapidfire, and welcome to Seven Forums.
When you have it finished, you could right click on the OEMInformation registry key and click on Export to have a .reg file. Afterwards, you could just merge (run) the merge the .reg file to set all of this automatically.
Hope this helps, :)
so if i export the .reg file and push it out to say 5 computers will it automatically change the make and model depending on the computer or is that not possible?
No. It will only change them all to whatever it was set as before exporting.
However, you could either edit the .reg file to change that entry then merge it, or change it in the registry per computer afterwards.
ok. that should be relativly easy to do.
where do i find the .reg file that contains the settings for it?
That would be the .reg file created when you export the OEMInformation registry key to say your desktop. :)
Done brink
Theres the review of my OEM Info
I`m trying to change the Manufacturer and Model in the 1st two screen shots below, not the manufacturer and model in Computer Properties, I`ve already done that, shown in the 3rd shot. Is there a way to do it ? For some reason it won`t change in those 2 areas.
