Windows 7: MS-DOS Bootable Flash Drive - Create
06 Jun 2011   #20
chickenmatt5
Windows 7 Starter 32bit
Alright, I just wanted to make sure that the USB would not replace Windows 7.
I sure won't be doing anything to that degree. I'm assuming that MS-DOS running from a USB stick could see the C drive; is that correct?
06 Jun 2011   #21
Brink
64-bit Windows 10 Pro
Correct, it will be able to see any drive connected to the computer.
06 Jun 2011   #22
chickenmatt5
Thanks for the responses! Off to try MS-DOS, then.
06 Jun 2011   #23
Brink
You're welcome.
27 Jul 2011   #24
S4LTnL1ghT
Windows 7 Ultimate & Windows 8 v.7989
Getting this message when trying to boot from USB Key:
Remove disks or other media. Press any key to continue.
Any suggestions?
27 Jul 2011   #25
Bill2
Quote   Quote: Originally Posted by S4LTnL1ghT View Post
Any suggestions?
Either that key is not bootable or the machine is incapable of booting from a usb key.
27 Jul 2011   #26
Brink
Any suggestions?
It just depends on if your computer is capable of booting from a USB key or not, and if it's a bootable USB key or not as Bill posted above. If it's a newer model computer, then most likely it is able to.
My Gateway laptop does this to me. I have to keep tappping F8 at boot to open the boot menu, then select to boot from the USB key drive. You may have a different F key to press instead at boot to open the boot menu though depending on what brand your laptop or desktop is.
12 Aug 2011   #27
phlibby
Windows 7 Ultimate 32bit
I just followed the steps and it works great. The only thing I would warn people is it takes a lot of room. I used a 500Gig USB Portable drive and it used up 380Gig. I have tried all kinds of tools to retrieve the space back but I believe it will probably make 3 quarters of any drive you use unusable. Just keep this in mind and don't use a big drive like I did.
UPDATE:
I just tried it again and instead of using the Quick Format option I just left the box unchecked for that and it worked just fine. It did not take up a lot of room. Hardly any. Good to go - Thanks.
03 Oct 2011   #28
preiius
Windows 7 Professional 64bit
Sorry to dig up an old thread.
Why not use 'internal MS-DOS system files' in the HP utility?
07 Oct 2011   #29
TeeDoubleUDee
Windows Home Premium 64bit
Saved my bacon, AGAIN
Many thanks again to Brink. This tutorial helped me reflash the faulty F/W on Samsung 2Tb Spinpoint HDD.
Create a bootable flash drive with SpinRite
I want to put SpinRite on a bootable flashdrive so I can run it. I want to be able to use the flashdrive with SpinRite on XP & Win 7. Do I create the bootable drive with Fat32 or NTFS? Have looked on line on how to create it but any suggestions would be helpful.
Software
Bootable USB flash drive
I have made a bootable flash drive that when run says bootmgr missing.This is a 8gb drive formatted ntfs,4gb used.I have remade this & very carefully followed the instructions on Google using the diskpart & th whole smear The one thing I'm not sure about is it said to copy the dvd to the flash...
Hardware & Devices
How to create Bootable USB drive
Hi, I want create a Bootable USB drive on my pen-drive for Windows 7. Searched on Google and this looked quite good: 4 Ways to Create a Bootable Windows 7 or Vista USB Drive Also, checked few tutorials on Windows 7 forum but wasn't sure how accurate they were. Simple I want step by step...
General Discussion
create bootable usb flash
hi my friends.i have some questions about creating bootable usb flash 1-i have an iso file of "windows password remover".the instruction said that i should write it on a Cd but can i want o have in on usb flash? i use ultraiso(open the iso file and in "bootalbe menu" use "write disk image") but it...
Hardware & Devices
Hi Folks, I have a 4GB Flash Drive, if I make it bootable, will their be any trouble in storing other data at the same time. I intend using it for installing Win7 and as Acronis Recovery, but not both installed at the same time.
Software
Win 7 X64 bootable flash drive
For security reasons, I would like to create a windows 7 X64 boot USB flash Drive , not an install drive. A drive where when I remove it, the system will not boot. What files do I need to put on the drive, or is there a progrm I can use to create it? My apologies if I'm not putting this in the...
General Discussion
