#20
Alright, I just wanted to make sure that the USB would not replace Windows 7.
I sure won't be doing anything to that degree. I'm assuming that MS-DOS running from a USB stick could see the C drive; is that correct?
Thanks for the responses! Off to try MS-DOS, then.
Getting this message when trying to boot from USB Key:
Remove disks or other media. Press any key to continue.
Any suggestions?
It just depends on if your computer is capable of booting from a USB key or not, and if it's a bootable USB key or not as Bill posted above. If it's a newer model computer, then most likely it is able to.
My Gateway laptop does this to me. I have to keep tappping F8 at boot to open the boot menu, then select to boot from the USB key drive. You may have a different F key to press instead at boot to open the boot menu though depending on what brand your laptop or desktop is.
I just followed the steps and it works great. The only thing I would warn people is it takes a lot of room. I used a 500Gig USB Portable drive and it used up 380Gig. I have tried all kinds of tools to retrieve the space back but I believe it will probably make 3 quarters of any drive you use unusable. Just keep this in mind and don't use a big drive like I did.
UPDATE:
I just tried it again and instead of using the Quick Format option I just left the box unchecked for that and it worked just fine. It did not take up a lot of room. Hardly any. Good to go - Thanks.
Sorry to dig up an old thread.
Why not use 'internal MS-DOS system files' in the HP utility?
Many thanks again to Brink. This tutorial helped me reflash the faulty F/W on Samsung 2Tb Spinpoint HDD.
