Install Windows 7 FAST without a DVD or USB device
Page 1 of 11 123 ... LastLast
    baarod
    How to Install Windows 7 FAST without a DVD or USB Device
    So far we've seen tutorials for installing Windows 7 in quite a few different ways. All of them require boot media like a DVD or USB key. All of them use the Windows 7 installer. All of them require you to upgrade or replace your existing Windows 7 installation. All of them are relatively slow. All of them are using technology designed by Microsoft for clueless end-users.
    This method uses technology designed for advanced users; OEMs like Dell, big IT departments and experts like us. It doesn't require extra bootable media and it leaves your existing Windows install intact. It's fast, it's flexible and it's all command line suitable for scripting.
    Let's start with the assumption that you've got a single hard disk with one big partition, it's not full, and you're already running some build of Windows 7 or Vista. If you've got more than one partition and can't figure out how to modify the steps in this tutorial to accommodate that please post a comment and I'll add the steps. The same goes for other hard disks. The only hard requirement is that you be running Windows 7 or Vista. We need to make room for the new Windows 7 install so we start by running DISKPART. Open Start, type diskpart and press Enter.
    Microsoft DiskPart version 6.1.7100
    Copyright (C) 1999-2008 Microsoft Corporation.
    On computer: ORION7
    DISKPART> lis vol
      Volume ###  Ltr  Label        Fs     Type        Size     Status     Info
      Volume 0     F                       DVD-ROM         0 B  No Media
      Volume 1     E                       DVD-ROM         0 B  No Media
      Volume 2     C   7            NTFS   Partition     16 GB  Healthy    System
      Volume 3     D   Data         NTFS   Partition    263 GB  Healthy
      Volume 4     G                       Removable       0 B  No Media
    DISKPART> sel vol 3
    Volume 3 is the selected volume.
    DISKPART> shr minimum=10240 desired=16384
    DiskPart successfully shrunk the volume by:   16 GB
    DISKPART> cre par pri
    DiskPart succeeded in creating the specified partition.
    DISKPART> for fs=ntfs quick label="7new"
      100 percent completed
    DiskPart successfully formatted the volume.
    DISKPART> ass
    DiskPart successfully assigned the drive letter or mount point.
    DISKPART> act
    DiskPart marked the current partition as active.
    DISKPART> lis vol
      Volume 3     D   Data         NTFS   Partition    247 GB  Healthy
    * Volume 5     H   7new         NTFS   Partition     15 GB  Healthy
    DISKPART> exi
    • Select the volume to shrink from the list with "sel vol"
    • Specify the minimum and desired volume size in megabytes with "shr"
    • Specify your own label for the new volume with "for"
    • Make note of the drive letter of the starred volume after "ass"
    Now crack open a Windows 7 ISO and extract the file \sources\install.wim. I just mount the file directly with CloneDrive: elby Free Software but your favorite ISO or archive program should be able to do this as well. Download imagex.zip, extract and open an elevated command prompt there.
    D:\Mike\Desktop\work>imagex /apply e:\sources\install.wim 5 h:\
    ImageX Tool for Windows
    Copyright (C) Microsoft Corp. All rights reserved.
    [ 100% ] Applying progress
    Successfully applied image.
    Total elapsed time: 7 min 8 sec
    D:\Mike\Desktop\work>h:\windows\system32\bcdboot h:\windows
    Boot files successfully created.
    Now reboot and a few minutes (less than 5 on my box) later you'll be prompted for locale info and to create a user. Welcome to your new Windows 7 installation.
    To toggle back and forth between this new installation and the original one use diskpart.
    On computer: ORION7
    DISKPART> lis vol
      Volume 1     E   GRC1CULFRER  UDF    DVD-ROM     2413 MB  Healthy
      Volume 4     H                NTFS   Partition     15 GB  Healthy
      Volume 5     G                       Removable       0 B  No Media
    DISKPART> sel vol 2
    Volume 2 is the selected volume.
    DISKPART> act
    DISKPART> exi
    • Select the volume containing the Windows installation you want to start from the list with "sel vol"
    Please post issues, questions or other feedback here.
  1. Posts : 651
    Well done. This is the kind of technical information needed for some of the more advanced users. Good work. :)
  2. Posts : 1,003
    Win7 Ultimate x64 on Desktop / Win7 Ultimate x86 on laptop / Win7 x86 Starter on Netbook
    Great Tutorial. :)
    The thing that always makes me laugh a little is that DOS is still useful as a command line language. :)
  3. Posts : 851
    win 7 build 7600.16385 x64
    Romulinx2 said:
    Great Tutorial. :)
    installing an most advanced OS using command in DOS is something great!!!:)
  4. Posts : 15
    Problem with second system
    Hi.
    Let me start from the beginning.
    I've downloaded W7 RC 7100 wrom MS site.
    I burned it to DVD and tried to instal but I was getting error every time (0x80070002).
    So I searched the web to solve the problem and found Your solution.
    I followed it step by sep and everything was great.
    But after using imagex when I was trying to use the command "bcdboot ..." I got error.
    It was offcourse because I was using Win XP at that time.
    So I found a sollution (at least I thought so).
    I restarted my PC, poped in the W7 DVD I burned earlier and when the setup started I hit "Repair the system".
    Everything was going ok, W7 was found and repaired. Than it started with no problem but as it occurred - my "previous C" partition was kind of disabled (screen from diskpart below).
    So what do I do to enter my Win XP partition and not lose data from it (I have some files there that would be nice if I could recover them).
    Please help...
    Screen:
  5. Posts : 1,519
    El Capitan / Windows 10
    Please help...
    Open diskpart and lis vol again, I'm assuming that vol 1 is the old XP. If it is just sel vol 1 and ass. That will assign a drive letter to vol 1.
  6. Posts : 15
    Thanks for the answer. Currently I am at work so don’t have possibility to try it.
    But I am curious about one more thing – will that partition be visible in boot loader?
    Or will I have to use bootcfg command?
    OK - I will see when I get home and try :)
  7. Posts : 1,519
    I'm honestly not sure about that, Luciak. I'm guessing that it will not be visible in the bootloader but I'm sure we can add it if you'd like...
  8. Posts : 15
    Wow - had some problems but finally I booted my old XP :)
    Your advice was very good and worked but as You also predicted, XP partition was not visible in bootloader.
    As I assigned the letter to my old XP partition I wanted to change it back to C:
    And I did - but it cost me faliure in W7 boot and no boot for XP.
    So I was a little bit crushed.
    I was fighting with it for few hours but it was worth it :)
    Finally I managed to add boot sequence for XP and I have learnt a lot bcdedit commands :)
    But it's working :)
    And my question is - can I somehow clean the bcd?
    Because as I understand it it is still in the system, just not visible from XP.
    Am I right?
    EDIT:
    Ok - I managed to clean it with easyBCD.
    EDIT II:
    I have a little comment to the quote below, according to my recent experience.
    You can do this operation also under Windows XP. The only difference will be tah You will not do whole operation in CMD.
    When You will get to this point:
    You will not be able to do this step:
    So what You have to do is to use EasyBCD to make Your new Windows 7 installation bootable.
    Very helpful here is this thread:
    How to Do a Dual Boot Installation with Windows 7 and XP
    Start from point 7. of Method II and just adjust it to Windows 7 instead of XP.
    Hope it will help someone to avoid the problems I had :)
    And once again thanks for support.
    Last edited by Luciak; 06 May 2009 at 16:06. Reason: Found the answer, Have some comments
  9. Posts : 1,519
    You can do the bcdboot command if you change directory to where the DLLs that it depends on exist. I just found this out and hadn't yet added it to the tutorial. XP has some of the same DLLs as 7 but they're the wrong version for bcdboot. What you do is CD to the dir (h:\windows\system32 in the example) then run bcdboot with that as the current directory. That will cause bcdboot to pick up the right DLLs and it will work OK.
