System Restore Point Shortcut
Page 3 of 19 FirstFirst 1234513 ... LastLast
  1. Posts : 80
    Windows 7 build 6956
       #20
    Oh, Shawn...I don't know what to say, just thanks so much. You are so enthusiastic
  2. Posts : 72,055
       #21
    You're welcome Natri.
  3. Posts : 22,814
    W 7 64-bit Ultimate
       #22
    Hello Brink....:)
    I know I already said thank you over at x64 but I just added this 'instant' to my 7 and I love it.
    Thanks Shawn!
    Later Ted
  4. Posts : 72,055
       #23
    You're welcome Ted. I'm happy to hear that it has helped you.
  5. Posts : 995
    XP/win7 x86 build 7127
       #24
    what if your system drive for win7 is D: ?
  6. Posts : 73
    Win7
       #25
    Thanks. Appreciated.
  7. Posts : 72,055
       #26
    You're welcome Ekopaxus. :)
  8. Posts : 72,055
       #27
    Hello Digger,
    If you have Windows 7 running, it should be considered as the C: drive in Computer. The shortcut should work just fine to create a restore point for the drives you have set in System Protection.
  9. Posts : 73
    Win7
       #28
    As mentioned above, Thank you.
    Does anybody know why the file created is deleted after I restart? Nothing under restore.
    Thanks.
  10. Posts : 72,055
       #29
    Hello Ekopaxus,
    If you mean the restore point, then it takes a bit for it to be created and to show up in System Protection to be available to restore from.
