Shell Command
    Shell Command
    Shell Command
    How to Use and See All Windows 7 Shell Commands
    How to See and Use a List of All Windows 7 Shell Commands
    This will show you a list of Windows 7 Shell commands that can be used to open certain special folders directly from the Start menu or Run dialog window.
       Tip
    You can find the shell commands listed at this registry location:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\explorer\FolderDescriptions
    The Shell commands that are new in Windows 7 from Vista are bolded in red.
    You can use the shell commands with either format below:
    shell:command
    OR
    explorer shell:command
    Here's How:
    1. Open the Start menu and type in the shell command in bold below for the folder that you want to open, then press Enter. (See screenshot below)
    OR
    2. Open the Run dialog window, and type in the shell command in bold below for the folder that you want to open, then press Enter. (See screenshot below)
  1. Posts : 18,404
    Another good one Shawn. Especially since now we can copy and paste in the start menu! We appreciate all your hard work in making the tutorials.
  2. Posts : 72,058
    It made my day to when we could finally copy and paste in the Start menu search line using the right click and not without having to use Ctrl+V again. :)
  3. Posts : 18,404
    It just shows you how something so simple can be missed if gone.
  4. Posts : 1,003
    Win7 Ultimate x64 on Desktop / Win7 Ultimate x86 on laptop / Win7 x86 Starter on Netbook
    Thanks, useful info to know. :)
  5. Posts : 72,058
    You're welcome Romulinx. :)
  6. Posts : 229
    Windows 7 64 bit
    Very useful share..thank you
  7. Posts : 72,058
    You're welcome Artinusa. :)
  8. Posts : 44
    Microsoft Windows Professional 32bit
    Great job, fantastic! Thanks a ton
  9. Posts : 72,058
    You're most welcome Fran, and welcome to Seven Forums. :)
