#50
You're most welcome Modrzew. :)
Hey guys,
I am using win98 theme for my win7, regrettably when I open several sub windows (skype for example) when I hover over any of them, a list of all sub windows appears.
I am pretty sure this was intended behavior on standard settings, but come on...
Hello Lazy, and welcome to Seven Forums.
Could you post back a screenshot of this just so that we can see it and be sure of what to suggest. :)
Here is the shot...
This popup is quite annoying. I have increased the time for it's appearing, but sometimes it just ignore this value...
Hello Lazy,
You can do OPTION ONE in the tutorial below to disable list mode as well. :)
Taskbar Thumbnail Previews - Enable or Disable
Thank you. I will test it for few days and update (although I am pretty sure, it will work)
The second registry file links to an image instead of reg file. Please correct this!!!
