#40
PvtMatter,
With all of the different issues you are having, you might consider backing up anything that you do not want to lose while in Safe Mode, then do a clean reinstall of Windows 7.
PvtMatter,
Shawn:
before I do a reinstall can I delete all user accounts except the original one I had, Larrry-PC\Administrator and try that?
If you have access to the Larry-PC account, then sure you can delete the other accounts while logged in the Larry-PC account if you like. Hopefully that will work for you.
Thank you thank you thank you!!!!!!!!!
Just fixed my problem!!
Great tutorial. Thanks a lot.
hope you dont mind me posting this here brink i found a program **Rebuild Icon Cache version 0.7b** that does the same as your tutorial see what you think http://screeny05.deviantart.com/art/...0-7b-164152806
After the last step of restart, all of my computer's icons have been gone.Help me.There are no icons.Even, start menu isn't opening.
try this program i posted **Rebuild Icon Cache version 0.7b**
Rebuild Icon Cache v0.7b by ~screeny05 on deviantART
