Icon Cache - Rebuild
Page 11 of 31 FirstFirst ... 91011121321 ... LastLast
  1. Posts : 960
    Windows 7 Ultimate SP1 - 64 Bit
       #100
    A little bug spotted with Option One using the .bat.
    When it asks if you want to restart your computer or not, pressing "N" will actually open an explorer window navigated to Libraries and restart your computer.
  2. Posts : 72,062
       #101
    Ooops, thank you Infinite. All fixed and updated to be even better now. :)
  3. Posts : 960
       #102
    That looks a lot better, thanks, however it still opens the Explorer Window which doesn't matter too much.
  4. Posts : 72,062
       #103
    What? It doesn't for me when I type n or N and press Enter.
    It's suppose to restart explorer, and wait for you to close the command prompt window. At least it does for me.
  5. Posts : 960
       #104
    Oh nevermind, it was probably because even though I re-saved it to my Desktop, it probably didn't update or something. Downloading it to another location fixed it. Nice one :)
  6. Posts : 72,062
       #105
    Ah, ok. :)
  7. Posts : 6
    windows 7 64 bit
       #106
    icons curruption
    thank you for this, it worked for my malwarebytes and glary utilties icons. what i would like to know, is why? this computer is less than two weeks old, this is the first issue which i would consider to be a windows 7 issue, as with my old xp nothing like this occurred.
  8. Posts : 72,062
       #107
    You're welcome Rusty, and welcome to Seven Forums.
    There's a number of reasons for why the icon cache could have gotten corrupted. Anywhere from lost file associations to HDD corruption. It's usually nothing to worry though about unless it happens on a regular basis. :)
  9. Posts : 313
    Vista/Win7/8/10/11 (x86/x64)
       #108
    ..Rebuild_Icon_Cache.bat..
    This makes it easy, thanks Brink
  10. Posts : 72,062
       #109
    You're most welcome endeavor. :)
