Icon Cache - Rebuild
Page 18 of 31 FirstFirst ... 8161718192028 ... LastLast
  1. Posts : 34
    Microsoft Windows 7 Home Premium 64-bit SP1
       #170
    YEP!!!! THAT'S OK! The problem is just the icons only for word and pdf files
  2. Posts : 72,082
       #171
    That's good so far. Please go ahead and post a screenshot showing what icon is currently displaying for them to see if it may help ID what the issue could be. :)
  3. Posts : 34
       #172
  4. Posts : 72,082
       #173
    As a test, reinstall the programs that you have installed to open these files to see if it may be able to repair it and the icon.
  5. Posts : 34
       #174
    Thanks! I will try:)
  6. Posts : 34
       #175
    Hi, I reinstalled Acrobat Reader and the problem with PDF Icons has been fixed !
    The problem persists with Word .doc files. Here is a couple of screenshots according to Microfot Office Enterprises:
    The problem is that I cannot proceed with any change or repair because I got this message:
    I wait for many hours till set up prepares the necessary files but nothing happens and set up does not start!
    I have also tried Microsoft Office Diagnostics and the TEST was successfully completed except this error:
  7. Posts : 72,082
       #176
    In that case for now, check in Default Programs to make sure that Word is set as the default program with all of it's associations to see if that may help.
    If not, are you able to run the Office installer from it's installation DVD to do a repair install instead?
  8. Posts : 34
       #177
    I do not see word under Default Programs:
    but I see all associated files without icons under Microsoft Word extensions:
    Last edited by Brink; 25 May 2013 at 14:08. Reason: attached images using "paper clip" icon into post
  9. Posts : 72,082
       #178
    Are you able to run the Office installer from it's installation DVD to do a repair install of Office and Word instead?
  10. Posts : 34
       #179
    Unfortunately No , because I do not have the DVD
