Icon Cache - Rebuild
Page 20 of 31 FirstFirst ... 10181920212230 ... LastLast
  1. Posts : 72,055
       #190
    You're welcome. :)
  2. Posts : 34
    Microsoft Windows 7 Home Premium 64-bit SP1
       #191
    Brink said:
    You're welcome. :)
    From now on, Ι will trust only https://www.sevenforums.com
  3. Posts : 4
    Windows server 2008 R2 Standard 64-bit (6.1, Build 7600)
       #192
    Option 2 worked like a charm, Thanks
  4. Posts : 9
    Win 7
       #193
    awesome. this worked and the missing program icons in the taskbar re-appeared even without a restart
  5. Posts : 2
    windows 8
       #194
    I restored icons by simply renaming the IconCache.db to include the word old and restarted my laptop.
  6. Posts : 72,055
       #195
    Hello netmouse, and welcome to Seven Forums.
    That would work as well, but now you have an unneeded backup copy of your old corrupted icon cache taking up space on the HDD.
  7. Posts : 2
    windows 8
       #196
    Not a problem at all. The file is only 167 kb (so tiny) and you can delete it. Right?
  8. Posts : 72,055
       #197
    Correct, or use Option One in the tutorial to have it all done for you automatically. :)
  9. Posts : 2
    Window 7 Starter
       #198
    This was what I needed. However, there's no need to reboot the entire system. Running explorer.exe as the last step is all that's needed to reload the user shell.
  10. Posts : 72,055
       #199
    Hello Semicharm,
    Yeah, sometimes that's all that may be needed if you just needed to have the cache cleared instead of rebuilt. I just include restarting the PC to be safe since it is needed to have the new hidden IconCache.db file recreated. :)
