Icon Cache - Rebuild
Page 26 of 31 FirstFirst ... 162425262728 ... LastLast
  1. Posts : 2
    Windows 7 Ultimate x32
       #250
    Invader440 said:
    Recently had the black icon problem also (I had previously got rid of the icon arrows several months ago). Running the rebuild icon cache program worked until I restarted the computer and then they went back to black squares. What I ended up having to do was to restore the icon arrows and now the icons are displaying correctly again.
    Yea well, very cool but not a solution.
    I have exactly same situation.
    And what you are proposing is basically "forget your dream" kind of option which is opposite of what the topic is about.
  2. Posts : 72,062
       #251
    Hello Jeck, and welcome to Seven Forums.
    If you are wanting to remove the shortcut arrows, then you might see if using a different option below may work better.
    Shortcut Arrow - Change, Remove, or Restore
  3. Posts : 2
       #252
    @Brink
    Thanks, 1st (program) method worked, which I didn't try at first bcos I don't like installing side programs and only now read that it doesn't install xD
    ty again
  4. Posts : 72,062
       #253
    You're most welcome Jeck. :)
  5. Posts : 2
    i've tried all method in page 1 but its still not fix my problem..
    see
  6. Posts : 72,062
       #255
    Hello kry666, and welcome to Seven Forums.
    You have an issue with your shortcut arrow overlay on the icon instead of with the icon cache. You can use an option in the tutorial below to restore the default shortcut arrow overlay to fix this for you. :)
  7. Posts : 2
    Wow great!!! its working for me using option 4 , i thought its was icon cache problem.. thanks a lots for helping me, now i can sleep in peace
  8. Posts : 72,062
       #257
    You're most welcome. :)
  9. Posts : 1
    WINDOWS 7 64 Bit Home Premium
       #258
    THANKYOU SO MUCH!!!!
    Do you know how long i've been searching for this solution?
    You have just reached godlike status in my opinion!
    Thankyou so very much!
  10. Posts : 72,062
       #259
    I'm glad it could help VIKING4650, and welcome to Seven Forums. :)
