Icon Cache - Rebuild
Page 3 of 31 FirstFirst 1234513 ... LastLast
  1. Posts : 72,051
       #20
    It's a hidden file. Did you set Folder Options to Show hidden files, folders, and drives?
  2. Posts : 34
    7
       #21
    In case it found the file i even moved it to a thumb drive and pulled the drive out.
    still the same....
    found the file - yes it was set at show hidden folders.
    i deleted it
    emptied recycle bin
    as i clicked restart - it appeared again - stubbern little cus isn't it.
    same with shut down- appears BEFORE the computer shuts down.
  3. Posts : 72,051
       #22
    That's normal. The IconCache.db file will automatically recreate itself. Deleting it just clears and resets the icon cache. Restart as soon as you delete it instead though.
  4. Posts : 34
    7
       #23
    no improvement
    icon pics still missing.
    and on a MS product! streets and trips 2010
  5. Posts : 34
    7
       #24
    system restore cured the problem.
    removing irfanview
    sadly only temporary
    I hate win7
    all it does it make MS even richer
    Issue continued in original thread:
    win7 desktop icon problem
  6. Posts : 34
    7
       #25
    an email link led to here asking for a screenshot.
    no need. it is the standard standin icon a picture with little boxes in it.
    for adobe elements 5
    reinstalling streets got its icon going.
    thanks
  7. Posts : 72,051
       #26
    That's great news Anon. I'm happy to hear that you got it sorted. :)
  8. Posts : 117
    Windows 7 Pro
       #27
    Just curious. What could cause the icons to become corrupted?
    Is it a case of power failure / connection failure / fan failure leading to the corruption of the system's registry keys, which then cause the icons to become corrupted?
  9. Posts : 72,051
       #28
    Hello Ravanx,
    It could be a number of things that may cause a icon to become corrupted. Here are some usual causes though:
    • Icon cache itself becomes corrupted causing the icons to not load or load incorrectly.
    • Shortcut loses it's association with it's target file location.
    • The desktop or Windows Explorer window did not refresh properly to show any change that may have been made.
    • If a bad attempt was made to change the icon.
  10. Posts : 117
    Windows 7 Pro
       #29
    What are the usual causes of the two above scenarios you pointed out??
