I've added a tip from one of our members, see: Part Three: To Change Command Prompt Layout
For HairyPaulSack: Clink may be the reason why you're not seeing the buffer list as it's overriding the buffer with its own list, can you disable Clink to test? Meanwhile, I'll look into it.
For Brink: Can you check the auto notification for this tutorial? I wasn't notified that Hairy posted.
