#20
Excellent, works like a charm
Strange thing is that the 'Run as administrator' context menu item is still present LOL
Just had to re-install 7260 so was perfect chace to setup the Administrator account right from the get-go
LOL, now that is funny that "Run as administrator" is still there in the built-in Administrator account.
thanx brother ....
but the problem is still there. . it is newer version of VISTA i am using. . if i do wat u said . . .i still can't find USER/GROUP tab. . i have tried through COMMAND PROMPT but no use!!!!!! simply i am not allowed to change any settings .... even time........ the main thing is that whenever i am accessing sumthing(like settings), it ask for a password but does'nt show where to type!!!!!
help !!!!
It will not let you unless you do this while logged in an administrator account though to make the changes for the built-in Administrator. You cannot do it from a Standard account.
We assumed that you were using Windows 7 though. If you are using Vista, then you might also see are sister site Vista Forums to post this at for more help specifically for Vista instead.
Brink, you are a star!
Why does Windows 7 have to be such a pain?
Corporates will never go for it.
PeterM
Hi peter and welcome to seven forums
I would think that corp's with their IT staff would like a more secure system. The IT guys (like myself) are the ones with the headache but hey its a job and somebody has to do it
Ken
Hi Peter,
I'm with Ken. They want to be able to keep control of their systems to make them easier to maintain and help keep them problem free.
Im with brink
Not running as admin can be a pita, but it also helps keep out infections, and poorly coded apps.
Aside from the prestige (is there any?) of being called admin, and having to fix anything that breaks a std user can do almost anything
