Built-in Administrator Account - Enable or Disable
Page 1 of 29 12311 ... LastLast
    How to Enable or Disable the Built-in Administrator Account in Windows 7
    How to Enable or Disable the Built-in Elevated Administrator Account in Windows 7
    This tutorial will show you how to enable or disable the built-in elevated Administrator account in Windows 7.
    You must be logged in as an administrator to be able to do the options in this tutorial.
    Standard user (Users) - The standard account is an unelevated restricted users account. It can help protect your computer by preventing users from making changes that affect everyone who uses the computer, such as deleting files that are required for the computer to work. It is recommend to create a standard account for each user instead of an administrator account for the user. When you are logged on to Windows with a standard account, you can do almost anything that you can do with an administrator account, but if a standard user wanted to do something that requires elevated rights that affects other users of the computer, such as installing software or changing security settings, Windows will give the standard user a UAC prompt to enter the password of an administrator account for approval and confirmation before allowing the action.
    administrator user - Is an unelevated administrator account that is created by default during the installation of Windows 7, or is already setup or you on a OEM (ex: Dell) computer. An administrator account has complete access to the computer, and can make any desired changes. To help make the computer more secure, this administrator account type will be prompted by UAC by default to give confirmation before allowed to make any changes that require elevated administrator rights. Such as those that affect the system, other users, or when running anything elevated (Run as Administrator) since running elevated will allow it to have access to the entire computer.
    Built-in "Administrator" - Is the hidden elevated administrator account that has full unrestricted access rights and permission on the computer. By default, this elevated "Administrator" account is not prompted by UAC by default to provide confirmation before allowed to make any changes that require elevated administrator permissions since it is an elevated account.
       Warning
    If you enable the built-in Administrator account, then it is recommended to create a password for better security.
    For additional security purposes, it is also not recommended to leave the built-in Administrator account always enabled, or to use it for everyday purposes.
    For the updated Windows 10 tutorial, please see here: Administrator account - Enable or Disable in Windows 10 - Windows 10 User Accounts Tutorials
    OPTION ONE
    Enable built-in Administrator in Local Users and Groups
    NOTE: This option will only be available in the Windows 7 Professional, Ultimate, and Enterprise editions.
    1. Open the Local Users and Groups manager.
    2. In the left pane, click on the Users folder. (See screenshot below step 3)
    3. In the middle pane, right click on Administrator and click on Properties. (See screenshot below)
    Built-in Administrator Account - Enable or Disable-local_users_and_group.jpg
    4. To Enable the Built-in Elevated Administrator Account
    A) Uncheck the Account is disabled box. (See screenshot below step 6)
    B) Go to step 6.
    5. To Disable the Built-in Elevated Administrator Account
    A) Check the Account is disabled box. (See screenshot below step 6)
    6. Click on OK. (See screenshot below)
    7. Close the Local Users and Groups window. (See screenshot below step 3)
    8. Log off, and you will now see the built-in Administrator account log on icon added (enabled) or removed (disabled) from the log on screen. (See screeenshot below)
    NOTE: Click on the Administrator icon to log on to the built-in Administrator account.
    OPTION TWO
    Enable built-in Administrator in an Elevated Command Prompt
    NOTE: This option can be used in all editions of Windows 7. If your Windows 7 uses another language than English, then you may need to translate the word administrator part of the commands below to your language to use instead.
    1. Open an elevated command prompt, and do step 2, 3, or 4 below for what you want to do.
    2. To Enable the Hidden Built-in Elevated Administrator Account
    A) In the elevated command prompt, copy and paste the command below and press Enter, and go to step 5 below. (See screenshot below)
    NOTE: If you had previously renamed the built-in "Administrator" account's name, then you will need to substitute administrator in the command below with the new name instead.
    net user administrator /active:yes
    3. To Enable the Hidden Built-in Elevated Administrator Account with Password
    net user administrator password /active:yes
    Substitute password in the command above with the password you want to use to log on to the built-in Administrator account.
    4. To Disable the Hidden Built-in Elevated Administrator Account
    net user administrator /active:no
    5. Close the elevated command prompt.
    6. Log off, and you will now see the built-in Administrator account log on icon added (enabled) or removed (disabled) from the log on screen. (See screeenshot below)
    OPTION THREE
    Enable built-in Administrator in Local Security Policy
    1. Open the Local Security Policy editor.
    2. In the left pane, expand Local Policies, and click on Security Options. (See screenshot below)
    3. In the right pane, right click on Accounts: Administrator account status and click on Properties. (See screenshot above)
    4. To Enable the Hidden Built-in Elevated Administrator Account
    A) Select (dot) Enabled. (See screenshot below step 6)
    B) Go to step 6.
    5. To Disable the Hidden Built-in Elevated Administrator Account
    A) Select (dot) Disabled. (See screenshot below step 6)
    7. Close the Local Security Policy window. (See screenshot below step 2)
    OPTION FOUR
    Enable built-in Administrator from System Recovery (WinRE) at Boot
  1. uwe
    windows 7 - 32
    this information has been very helpful - thank you! :)
  2. Posts : 748
    Vista and now 7 in 32 and 64 bit.
    Fwiw. You do not need the "yes" to enable, but do need "no" to disable.
    You can also, instead of lusrmgr.msc , type Control userpasswords2 , but it comes to the same window, and is more keystrokes
  3. Posts : 72,037
    Thank you for the addition Dave. It has been added. :)
  4. Posts : 72,037
    You're welcome uwe. :)
  5. Posts : 1
    Option two doesn't work:]
    cmd -> run as administrator
    "System error 5 has occurred. Access is denied"
  6. Posts : 72,037
    Hello Vaultboy, and welcome to Seven Forums.
    It works, but you must open a elevated command prompt instead as in step 1.
  7. Posts : 104
    Well its not POS Vista lol : )
    When I run CMD and type
    NET USER ADMINISTRATOR /ACTIVE:YES
    I get the same error message.
    "System error 5 has occurred. Access is denied"[/quote]
  8. Posts : 2,899
    try to get a elevated command prompt first before attempting this route
  9. Posts : 4,925
    Windows 7 Professional 64-bit
    "NOTE: You could also type Control userpasswords2 instead if you like since it takes you to the same window under step 4." I think the wording needs clarification. Its not good grammar.
