Built-in Administrator Account - Enable or Disable
Page 22 of 29 FirstFirst ... 122021222324 ... LastLast
  1. Posts : 72,058
       #210
    Kawa said:
    Hello guys, i didn't read all posts so i have a question, can i make my user to be "Built-in Elevated Administrator Account" ?
    Hello Kawa, and welcome to Seven Forums.
    While you cannot make your administrator account to be the built-in elevated Administrator account since there already is one, you can make your administrator account to have the same elevated rights as the built-in Admin using an option the tutorial below.
    How to Elevate All Administrator Accounts UAC Privilege Level
    Hope this helps, :)
  2. Posts : 9
    Windows 7 Ultimate x86
       #211
    Hello Brink, thanks for the welcome.
    That tutorial didn't help me how i want, i say this because even i followed i still get a warning "Destination Folder Acces Denied", i want to modify the startup/shutdown sounds...
  3. Posts : 72,058
       #212
    Hello Kawa,
    Is your account an administrator account? If it's a standard user account, then you're out of luck.
    What folder is this for?
    If you haven't already, you might see if taking ownership of the folder, and setting the folder's permissions to allow your account "Full control" will let you be able to afterwards.
    (step 2 in Option Three)
    Take Ownership of file
  4. Posts : 9
       #213
    My user seems to be an administrator account. Dwm 2013-12-18 15-42-33-71 - Dwm 2013-12-18 15-42-33-71.bmp - Minus
    In fact that's not even an folder, it's a file: "Windows Shutdown" (it's located in Windows\Media). I tried to take ownership but without results
  5. Posts : 72,058
       #214
    It seems that your account has some sort of permissions issue.
    As a test, create a new user account, make it an administrator type, and see if you area able to change sounds while logged in to the new account.
  6. Posts : 9
       #215
    Nope, doesn't work.
    I tried with Administrator user (not Kawa user) and i get same warnig.
  7. Posts : 72,058
       #216
    In that case, you might consider reinstalling Windows.
  8. Posts : 9
       #217
    Ok. Eh, i think that it was necessary anyway. Thanks a lot Brink :)
  9. Posts : 72,058
       #218
    I hope it goes smoothly.
  10. Posts : 26
    Microsoft Windows 7 Home Premium 64-bit
       #219
    Reply to Kawa.
    Yes, you can make user as a "Built-in Elevated Administrator Account"
    Follow the tutorial closely and remember that for security, it is also not recommended to leave the built-in Administrator account always enabled, or to use it for everyday purposes.
