Built-in Administrator Account - Enable or Disable
Page 23 of 29 FirstFirst ... 132122232425 ... LastLast
  1. Posts : 115
    Windows 7 Home Premium 64 Bit
       #220
    If I disable the Administrator account will the settings go back to default or will any changes made remain after the disable?
  2. Posts : 72,051
       #221
    Hello Casey,
    The settings will remain so that you can continue using them each time you enable the built-in Administrator next.
    If you wanted to reset the settings, you could delete the C:\Users\Administrator folder after disabling the built-in Administrator. This would cause it to be recreated to default the next time it's enabled.
    Hope this helps. :)
  3. Posts : 115
       #222
    Brink said:
    Hello Casey,
    If you wanted to reset the settings, you could delete the C:\Users\Administrator folder after disabling the built-in Administrator. This would cause it to recreated to default the next time it's enabled.
    Hope this helps. :)
    Thanks. That's just what I needed to know. :)
  4. Posts : 72,051
       #223
    You're most welcome. :)
  5. Posts : 1
    Gauteng
       #224
    I know this is a very old thread but it popped up when I had the System Error 5 problem so I'm posting this for future reference if someone else has the same problem.
    I tried everything I could find on Google but nothing worked - the I saw I had 2 domains on the PC and I was logging onto the wrong one with the Administrator PW - that's why it seemed that my Administrator account was deleted.
    I picked it up by going to Manage Users - Users - then I viewed the list of users (of which administrator was one) and I saw the domain read something different as to the one i was trying to log on to.
    I switched user, typed in DOMAINNAME\Administrator (no PW) and VOILA! I could do what was needed to do.
    I hope this helps someone somewhere that also gained gray hairs of struggling with this problem
  6. Posts : 2
    Windows 7 Ultimate
       #225
    I tried Options 1, 2, 3. I keep getting "Access is denied"
    I couldn't even complete Option 4!
    Please help!
    Some details about what happened:
    I accidentally deleted the domain administrator from my computer!
    I am logged into my computer using a local user, which has no administrator privileges. Then, I logged in as the domain administrator, and was trying to remove the domain administrator as being the only one in charge, but I didn't know that that meant I would be removing all administrators! :/
    I went to MANAGE USER ACCOUNTS (from User Accounts in Control Panel) and saw two users, and thought that by deleting both, that would be fine.
    DUMB MISTAKE!
    Now I can't make ANY changes to this computer because it has no administrator!
  7. Posts : 72,051
       #226
    Hello Isahrangme, and welcome to Seven Forums.
    Yeah, without being logged in to an administrator account, you will not be able to use Options 1, 2, 3 as you found out the hard way since you do no have access rights to do so.
    What happened with Method II in Option 4? Any error messages?
  8. Posts : 2
    Windows 7 Ultimate
       #227
    THANKS FOR THE QUICK RESPONSE!
    Haven't gotten around to Method II! I meant to try that tomorrow. I tried Method I, and when I typed in "list volume", it gave me some error (which I didn't record down).
    If Method II does not work, is there no other way?!
    There has to be SOME way to be able to add/remove users or remove the computer from the domain!
  9. Posts : 72,051
       #228
    Format and reinstall at boot would be an option, but let's hope it doesn't come to that.
  10. Posts : 5
    windows home premium 64bit
       #229
    ok i finally got it typed right and i think accepted how can i check to make sure?
