#220
If I disable the Administrator account will the settings go back to default or will any changes made remain after the disable?
Hello Casey,
The settings will remain so that you can continue using them each time you enable the built-in Administrator next.
If you wanted to reset the settings, you could delete the C:\Users\Administrator folder after disabling the built-in Administrator. This would cause it to be recreated to default the next time it's enabled.
Hope this helps. :)
I know this is a very old thread but it popped up when I had the System Error 5 problem so I'm posting this for future reference if someone else has the same problem.
I tried everything I could find on Google but nothing worked - the I saw I had 2 domains on the PC and I was logging onto the wrong one with the Administrator PW - that's why it seemed that my Administrator account was deleted.
I picked it up by going to Manage Users - Users - then I viewed the list of users (of which administrator was one) and I saw the domain read something different as to the one i was trying to log on to.
I switched user, typed in DOMAINNAME\Administrator (no PW) and VOILA! I could do what was needed to do.
I hope this helps someone somewhere that also gained gray hairs of struggling with this problem
I tried Options 1, 2, 3. I keep getting "Access is denied"
I couldn't even complete Option 4!
Please help!
Some details about what happened:
I accidentally deleted the domain administrator from my computer!
I am logged into my computer using a local user, which has no administrator privileges. Then, I logged in as the domain administrator, and was trying to remove the domain administrator as being the only one in charge, but I didn't know that that meant I would be removing all administrators! :/
I went to MANAGE USER ACCOUNTS (from User Accounts in Control Panel) and saw two users, and thought that by deleting both, that would be fine.
DUMB MISTAKE!
Now I can't make ANY changes to this computer because it has no administrator!
Hello Isahrangme, and welcome to Seven Forums.
Yeah, without being logged in to an administrator account, you will not be able to use Options 1, 2, 3 as you found out the hard way since you do no have access rights to do so.
What happened with Method II in Option 4? Any error messages?
THANKS FOR THE QUICK RESPONSE!
Haven't gotten around to Method II! I meant to try that tomorrow. I tried Method I, and when I typed in "list volume", it gave me some error (which I didn't record down).
If Method II does not work, is there no other way?!
There has to be SOME way to be able to add/remove users or remove the computer from the domain!
ok i finally got it typed right and i think accepted how can i check to make sure?
