Built-in Administrator Account - Enable or Disable
Page 5 of 29 FirstFirst ... 3456715 ... LastLast
  1. Posts : 72,062
       #40
    Hello c1ogden, and welcome to Seven Forums.
    If your edition of Windows 7 is say Home Premium, then it will not inlcude gpedit.msc or lusrmgr.msc.
    You will need to right click on the command prompt shortcut and click on Run as administrator to open a elevated command prompt instead for it to work. (Step 1 in OPTION TWO)
  2. Posts : 3
    Thanks Shawn.
    I tried that and got to the elevated command prompt. I entered "net user administrator / active:yes".
    Now it says "The option / is unknown."
    Anything else I should try? Thanks for the help!
  3. Posts : 72,062
       #42
    You're close, but there is no space between / and active.
  4. Posts : 3
    Thank you Shawn!
    That worked!
    Thanks for all your help!
  5. Posts : 72,062
       #44
    You're most welcome c1ogden. :)
  6. Posts : 4
    windows 7
       #45
    In elevated cmd promt. Typed "net user administrator/active:yes", and got syntax error.
    This is what was returnred:
    The syntax of this command is:
    net user
    [username [password | *] [options]] [/domain]
    username {password | *} /add [options] [/domain]
    username [/delete] [/domain]
    username [/times:{times | all}]
    My os is Windows 7 Home Premium
  7. Posts : 72,062
       #46
    Hello Two Dogs, and welcome to Seven Forums.
    Are you part of a domain? If so, then you may need to see your domain administrator.
  8. Posts : 4
    windows 7
       #47
    I don't know what you mean by a domain. I installed this on my pc and I'm the only user. I set up a standard account, a guest account, and myself as an admin account. I still get messages from the sytem telling me that I don't have permissions.
  9. Posts : 72,062
       #48
    Ah, you will need to do this while logged on to a administrator account, and right click on the command prompt shortcut and click on "Run as administrator" to be able to do this.
  10. Posts : 4
    windows 7
       #49
    I am.
    I did that.
