Built-in Administrator Account - Enable or Disable
Page 6 of 29 FirstFirst ... 4567816 ... LastLast
  1. Posts : 72,051
       #50
    Are you able to enable the built-in Administrator account using OPTION ONE instead?
  2. Posts : 4
    windows 7
       #51
    I Have Home Premium. I can't use option one.
  3. Posts : 72,051
       #52
    If you are logged into an adminstrator account, and used "run as administrator" on the command prompt shortcut, then you might try again to see if maybe you made a typo by mistake. You should not get a permission denied message unless you are not in a elevated command prompt.
    If the above does not work, then you might see if you can afterwards after you run a sfc /scannow command. If you still cannot, then you might consider doing a repair install.
  4. Posts : 7
    Windows 7 Ultimate
       #53
    Didn't there used to be an option where it could be doone via WinRE?
    If so, please put it on.
  5. Posts : 72,051
       #54
    Hello Anon,
    You can run the command to enable the built-in Administrator account from the command prompt option from WinRE. (see OPTION TWO below)
    Command Prompt at Startup
  6. Posts : 2
    Windows Seven
       #55
    TwoDogs have everythings fine with his computer. I have the same problem its on freshly installed Windows 7 Home Premium (x64 PL legal) it doesnt have files: gpedit.msc, lusrmgr.msc and the option 2 doesnt work too. Neither W7 Starter or W7 HP do not have it. I have Asus notebook and ive installed Asus SmartLogon program witch make able to logon by camera, unfortunalty beside the camera face window theres new account called: SmartLogon.
    First try:
    Ive trided by run>mmc> File>Add/Remove addon >
    there is users and local groups but when i try to use it windows says to me thet its Home Premium Eition and this addon cannot be used.
    Second try:
    by run>gpedit.msc
    file does not exist
    Third try:
    by run> lusrmgr.msc
    it opens !! but in the middle window there is same text as in first try.
    Forth try:
    by all program>accesories> command line (right click - run as administrator, for shure im at administrator account) > net user /?
    then i see:
    The syntax of this command is:
    net user
    [username [password | *] [options]] [/domain]
    username {password | *} /add [options] [/domain]
    username [/delete] [/domain]
    username [/times:{times | all}]
    (there is no /acitve option) but try to do it by writing:
    net user SmartLogon /active:no
    then i see this again:
    net user
    Fifth try:
    by control panel > user accaunts > manage other accaunts >
    there is no SmartLogon (??)
    tell me plz is there any other option to disable/enable or hide accaunts ?
    if not fully legal my there is posibliity to add/modify some files like gpedit.msc or lusrmgr.msc ??
    PS. sorry for my english, im polish.
  7. Posts : 50
    Windows 7 Pro 64-bit
       #56
    Grathiam said:
    ...Lastly, I must say how much I appreciate the extensive amount of user friendly info on 'sevenforums', as well as the efforts the admin and others have made to make this site so valuable. I vaguely recall (dementia? ) the lack of user info available on a single site when DOS, Win 3.1 and later OS's became available. This site is the best I've encountered for a primary OS!
    I will second that in spades... I've been lurking in forums, soaking up as much info as possible about my new Win7, and I have to say the tutorials here are the best I've ever seen... so much so, that even this Sr.Citizen can follow them. Excellent work Brink.
  8. Posts : 72,051
       #57
    You're most welcome Bootsmom, and welcome to Seven Forums. Thank you for the kind words. :)
  9. Posts : 2
       #58
    How to enable Administrator
    Hi i m not able to enable my administrator account as i have tried the option 2 but the message "Access is Denied" is displaying.
  10. Posts : 72,051
       #59
    Hello Sudhirphophaliy, and welcome to Seven Forums.
    Are you logged in a adminsitrator account?
    Be sure that you right clicked on the command prompt shortcut and clicked on Run as administrator so that it is a elevated command prompt that you are using.
    Hope this helps for now,
