Built-in Administrator Account - Enable or Disable
Page 11 of 29 FirstFirst ... 91011121321 ... LastLast
  1. Posts : 72,058
       #100
    Lio,
    You can't delete the built-in Administrator account. Instead you can only disable it as in the tutorial while logged in another administrator account (ex: LioSeven).
  2. Lio
    Vista/Seven
       #101
    Brink said:
    Lio,
    I've tried it but I don't have any possibility to disable.
    I also tried to enter in the administrator account (OverLio) but from there I only can delete MY REAL account, LioSeven and same from LioSeven.
    It's crazy!! I can delete my account (till 4 hours ago my ONLY account, with all my programs ..... ) but I cannot delete a new account just created.
    I'm going to try a restore point but because I've tried to install and uninstall so many time that damned LSS, I can only restore till 3 days ago
    and so I cannot solve any problem
    Thanks and... if you have some good idea :) I'm only waiting for any help
  3. Posts : 72,058
       #102
    Have you logged out of the built-in Administrator account, logged into your LioSeven administrator acccount, then try to disabled the built-in Administrator account using step 2 in OPTION TWO of the tutorial?
  4. Lio
    Vista/Seven
       #103
    And no luck in the restore too
    I already have the 2 account and this error too:
    It seems really every steps I do, I run in another problem
  5. Lio
    Vista/Seven
       #104
    I'm logged in my usual account LioSeven where I'm administrator and I have this reply if I use Command Prompt
    Microsoft Windows [Version 6.1.7600]
    Copyright (c) 2009 Microsoft Corporation. All rights reserved.
    C:\Users\LioSeven>net user administrator /active:yes
    System error 5 has occurred.
    Access is denied.
    C:\Users\LioSeven>
    So, ANOTHER ERROR
    OPS I see only now that I was not In the elevated Command Prompt, I try again
  6. Posts : 72,058
       #105
    Did you type the command in a elevated (right click "Run as administrator") command prompt?
  7. Lio
    Vista/Seven
       #106
    I just correct my previous post when I've seen that I was not in Elevated Command Prompt.
    And PLEASE, don't tell me to reinstall all.
    I'm now finishing to install my new system with all the program and till I have the problem with Lightscribe, all works like a charm and I was going to make the image of all the perfect installation to have my backup copy.
    It's only for this reason I don't have the backup: I need to have all setting up, with my Photoshop, all the plugins, all the link and so on.........
    I try with the elevated prompt
  8. Lio
    Vista/Seven
       #107
    Now I've disabled (I hope and I'll see when I login next time).
    But even I've solved this problem, I have the first problem: I cannot install the Lightscribe drive
    But for now, THANKSSSSSSSSSSSSS
  9. Posts : 72,058
       #108
    You're most welcome Lio. I hope you will be able to get the Lightscribe drive issue sorted soon as well.
  10. Posts : 2
    Windows 7 Home Basic 64-bit
       #109
    Hello,
    I've followed the steps in OPTION TWO of this tutorial, since my OS is Windows 7 Home Basic.
    1) Opened an elevated command prompt, as described in the indicated topic;
    2) When I typed the command net user administrator /active:yes , the system returned the message:
    The user name could not be found
    For more help, type NET HELPMSG 2221.
    So, after a lot of searching, I've discovered that the problem was that my system language is Brazilian Portuguese (I'm Brazilian, by the way). So, changing the command line to net user administrador /active:yes it worked as well as it should. Note that the word "administrator" was placed by "administrador", its translating in Portuguese. I think that it could help for the ones with systems in other languages too.
    Best Regards,
    negrometal
