Motherboard - Install in a case
Page 1 of 3 123 LastLast
    How to Install a Motherboard in a Case
    How to install a motherboard in a case
    For this you will need:
    * A screwdriver
    * Some screws which should have come with the case or motherboard to attach the motherboard with
    * A motherboard
    * A case
       Warning
    Remember to get the right case for your motherboard! If your motherboard is a mATX (micro ATX) you will need a case that has the holes for that sort of mobo
    Remember always to discharge yourself before doing anything like this! This is done by touching the metal inside the case.
    Also make the screwdriver touch it as well, so it is discharged as well
    Also, use standoffs if necessary. The standoffs insure that the mobo will not touch and short out.
    Installing the motherboard
    1. Remove the side panel from your case
    2. Remove the old silver plate from the back, and put in the one that came with your motherboard
    3. Now place the motherboard to match the screw holes in the case, and the silver plate at the back
    4. Screw the screws in, but be careful, only screw till you meet a little resistance as you dont want your mobo to crack
    5. Thats it. Your done installing the motherboard now, now you need to connect it to the PSU and the rest of your parts (tutorials on how to do this will be available in some months)
    Finishing up
    1. Put the sidepanel on again
    2. Screw the screws in
    Thats it, it's that simple.
    Good luck to all, if you got any question please do ask them below in this thread
  1. Posts : 11,990
    Windows 7 Ultimate 32 bit
    Very good. Good points about discharging staic electricity and over tightening screws.
  2. Posts : 4,755
    Thank you Carl :)
  3. Dom
    Windows Seven Ultimate
    Very nice
  4. Posts : 17,322
    Win 10 Pro x64
    Cool, Can't wait for the rest of the series. Nice work Sergio.
  5. Posts : 4,755
    Thanks guys :)
    I'm also looking forward to doing the rest of these series of tutorials. Just need a CPU, PSU and some Ram now and i will tuts for installing those
  6. Posts : 3,300
    Win7 Home Premium 64x
    I had to use metal standoffs when I installed a mobo for a friend. I didn't see this mentioned, but I think it is fairly common.
    Excellent Tutorial.
  7. Posts : 4,755
    Thank you Thorsen
    I dont know about those standoffs tho, i never used them.
  8. Posts : 11,990
    Sergio, you can edit it to include something like "use standoffs if necessary". The standoffs insure that the mobo will not touch and short out.
  9. Posts : 4,755
    Added, thanks Thorsen and Carl
