Windows 7: System Type - 32-bit (x86) or 64-bit (x64)
How to Tell if Windows 7 is a 32-bit or 64-bit System Type
Published by Brink
14 Nov 2008
information   Information
This will show you how to tell if you have a 32-bit (x86) or 64-bit (x64) Windows 7 version.
Here's How:
1. Press the Windows Key + Pause/Break key.
A) Go to step 3.
OR
2. Open the Start Menu.
A) Right click on the Computer button and click on Properties. (See screenshot below)
3. If You Have a 32-bit (x86) Windows 7 System Type
4. If You Have a 64-bit (x64) Windows 7 System Type
13 Feb 2010   #1
bird635
window 7
thank you sir
21 Feb 2010   #2
manasthehunck
Windows 7 Home Premium(32-bit)
HOW TO CHANGE 32BIT TO 64 BIT....(NOTE) I HAV WARRENTY PERIOD REMAINS 7 MONTHS.....
21 Feb 2010   #3
Brink
64-bit Windows 10 Pro
Hello, and welcome to Seven Forums.
Sorry, but the only way to go from 32-bit to 64 bit Windows 7, or in reverse, is to do a clean install with the one you want to install.
20 Mar 2010   #4
MadMaxData
Windows 7 Enterprise x64
Quote   Quote: Originally Posted by Brink View Post
You can always edit the "System Type" text, but it won't change your OS platform one iotta...LOL
20 Mar 2010   #5
Brink
LOL, now I suppose that is one workaround.
27 Mar 2011   #6
duanebytes
Sorry for bumping. If I do a clean install, can I install Windows 7 Ultimate x64 on my x86 machine?
27 Mar 2011   #7
Brink
Hello Duane,
Yes, since you have a 64-bit CPU you will be able to. You will also need to make sure that you hae 64-bit drivers available for all of your devices as well to install after Windows 7.
27 Mar 2011   #8
duanebytes
I want to install in my old machine. And I think it's a 32-bit CPU.
2GB RAM.
27 Mar 2011   #9
Brink
If it's a 32-bit CPU, then you will not be able to install 64-bit Windows 7 on it. Plus, with only 2GB of RAM, you would be better off with 32-bit Windows 7 installed on it.
What's the CPU brand and model number?
Wrong system image type?
I've recently bought a new WD 1TB HDD to replace my (really) old Samsung 500GB HDD. I created a system image, then unplugged the old HDD, plugged in the new one and put in the win7 installation disk. I went to restore it from a system image, however, it said something along the lines of not being...
Backup and Restore
system type and processor speed
hi processors have speeds like 2.7GHz and this actually a frequency at which it runs .. frequency is cycles per second .... 2.7GHz = 2.7*1024*1024*1024 = 2,899,102,924.8 Hz i.e cycles per second or pulses per second . i think 2,899,102,924.8 bits per second such processor is said to...
Hardware & Devices
Cannot type in System Password
I recently upgraded to Window 7 Home 64x from vista ultimate 32x. I also installed 8gb of RAM. I downloaded all the drivers/updates and everything was fine. Then, I entered in a System Password and an admin password in the set up menu since this hasnt been done previously. Once I rebooted, it...
General Discussion
Partition File System type on new OEM HD
I have Vista running on Disk 1 as C:, getting ready to multi boot with Win 7. Just installed a 1TB Seagate Barracuda 7200.12 HD (OEM) as Disk 2. The first partition on the disk is Unallocated, 7.84Mb, Status None and Type Logical. If I want to install Win 7 on Disk 2 in it's own partition what...
Performance & Maintenance
CSC-Cache as File System Type
Hello new windows 7 user (1 month) and first time poster here. I've got a problem that I can't seem to find the solution to after searching extensively. I am running Win7 Business 32bit on an AMD Dual Core Platform 2.4g with 2gb of RAM. I have a Buffalo Linkstation Pro NAS which all of my...
Network & Sharing
Twitter Facebook
