#50
You're most welcome onlytanmoy. :)
Works great, just what I was looking for!
THanks,
dev
Followed directions but after pressing run a note pad window opens with the following
"Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\AllFilesystemObjects\shellex\ContextMenuHandlers\{C2FBB630-2971-11D1-A18C-00C04FD75D13}]"
but no further instructions or choices. I assume the key must be inserted in the registry but where?
regards
Hello Captrip, and welcome to Seven Forums.
It sounds like your REG file extension associations are messed up and are not letting you merge a REG file.
Double check in Default Programs to set the reg file extension to have it's Current Default program set as Registry Editor (C:\Windows\regedit.exe). Afterwards, try merging the REG file from the tutorial again. :)
Hello Ted,
Not at all. I had many people ask to only have one or the other item added to the context menu instead of both, so I just split them to make it easy to add just one or both. :)
