#70
thanks
thanks
I love this kind of efficient working, but I personally have found eliminating the mouse as much as possible is the best way and that's worked for me for some time. I was initially intrigued by this as it may be useful to have a quick way to send something to (a folder on) the desktop for example, however I still would find using a combination of ctrl+c then ctrl+v (maybe adding a windows+D in-between there to get to the desktop or windows+e to bring up 'computer' followed by either usage of alt+tab to switch between windows, or tab to move around in a window and the arrow keys or even F3 in some cases if the destination folder is buried obscurely in a potentially unknown location or is simply too many folders deep amongst highly populated folder structures)
Now is there anything anyone can build on or pick apart with my system. I'm very open to criticism as I have after all criticised this method of using the mouse. Perhaps there's something I'm missing or some kind of flaw with my system for some?
reg keys not working, the remove one's. windows 7
FIXED IT>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
To fix the issue i opened the reg key's with notepad and went to the reg key location and there were keys forCopy To and Move To, I just deleted them keys and the options were gone on the context menu. hope this helps anyone else with this issue:)
Hello SexyBlonde, and welcome to Seven Forums. :)
They're working fine for me. You might check to make sure that you approved all the prompts at step 5. Missing any one of them will cause the remove .reg to not work.
woo hoo, they work :) thank you Brink :) I don't know if the uninstall work as I won't be getting rid of them, they are too usefull these copy & move context menu thingys :) cheers
I followed the instructions in the Tutorial to Add Copy to Folder and Move To Folder and installed the registry entries per instructions but the items do not show in the right click context drop down items. Am I doing something wrong?
TIA
Mary
Hello Mary,
These context menu items will only show up when you right click on a file or folder, and nothing else.
Were you logged in to an administrator account when you merged the .reg files?
Did you use the .reg files from step 1 in both Option One & Two?
This context menu item will only show up when you right click on a file or folder, and nothing else.
Hope this helps for now, :)
Shawn,
OK now I understand duh. Now it works. Many thanks for your patience and assistance.
Mary
