#90
erewhon,
Were you able to drag the bottom border of the dialog up to make it smaller so that it will fit on your screen, then close the dialog to see how it opens next?
erewhon,
Wow! That worked Brink. The upper limit is set, but not the lower.
Now the other problem is worse! Having all those sub-folders expanded in such a small window is a real pain.
Anything we can do with that?
About all you can do is to drag the bottom border down as far as you can without it going off screen, and close the dialog. After that, it's a matter of having to use the scroll bar.
You should be able to collapse them, then close the dialog to have them open the same way afterwards.
After some playing, the dialog opens expanded to the same location you last copied or moved to. "This PC" seems to always remain expanded as well.
I don't see a way to change this behavior.
I am registering here only to say thanks to Brink for this extremely useful registry hack.
Thanks so much for these registry hacks. They work perfectly. One of my final steps in forcing Windows 7 to do what I need (and what it should have been able to do in the first place).
