#30
I don't know whether your setup would be possible. But what you could do is use "send to" a number of predefined folders. All you have to do is to include shortcuts of the desired folders into the "Send to" folder.
Place shortcuts of the desired folders on the desktop, then type shell:sendto into the Start/search, hit Enter and drag your shortcuts into the sento folder. Close the send to folder. Now, whenever you go to "Send to" in the context menu, your folders will be one of the pop-up options.
Send To Context Menu - Vista Forums
Note: Send to equals a copy, not a move.
