Page 8 of 33 FirstFirst ... 67891018 ... LastLast
  1. Posts : 72,051
       #70
    You're most welcome. :)
  2. Posts : 21
    Windows 7 Professional 32bit
       #71
    Sorry Brink
    I cancel the Clean All process. When I List Volume under Diskpart, apparently the only Volume appeared is DVD-ROM.
    Then I performed the following step:
    1. Select Disk 0
    2. Create partition primary size=152369
    (At this stage the Fs = RAW)
    3. Active
    4. Exit and Exit
    Then I performed the System Image Recovery and following all the steps requested until last step Re-Image your Computer. Oop..
    Error: No disk that can be used for recovering the system disk can be found
    Why?? What did I missed out in the setting? Do I need to format it to NTFS before I restore System Image Recovery?
  3. Posts : 72,051
       #72
    Did you run the "Clean" command on it after interrupting the "Clean All" command? Yes you would need to format the HDD afterwards as NTFS.
  4. Posts : 21
       #73
    Yes. After I interrupted the Clean All process. I did do the Clean according to your advice.
    As a result of above action:
    What appears after I List Volume is - DVD-ROM
    1. Select Disk 0
    (Now I could see a new Volume 1 Fs= RAW, Allocated size=149G, Free size=0)
    3. Active
    Finally, while waiting for your feedback, I performed the following step.
    4. Format fs=NTFS label="Local Disk"
    I wish I did it correctly and it is progressing very very slow. The speed of formatting is like 2% per every hour. After I let it running for 8 hours, it just progress up to 18%. I reckoned it requires another 36 hours to complete.
    I hope it would not pop up error again when come to final stage of "Re-Image Your Computer". One question at this stage, will the formatting at this stage will take the same amount of time or quicker?
    This is really a dreadful exercise.
  5. Posts : 435
    Will this remove viruses, I think I might be crawling with them on both PCs. I can easily reinstall Windows.
  6. Posts : 72,051
       #75
    Hello Joe,
    It will remove everything including a virus from the HDD that the commmand is ran on. :)
  7. Posts : 435
    Can I do this right now without using the disk, then 2 days later, ask my Brother for Windows 7?
  8. Posts : 72,051
       #77
    1. Select Disk 0
    3. Active
    The Format fs=NTFS label="Local Disk"you did was for a "full format". It will take a bit to finish.
    Next time, you could use the command below instead to perform a "quick format" that will finish fast.
    Format fs=NTFS label="Local Disk" Quick
  9. Posts : 435
    1. Select Disk 0
    3. Active
    I skim-read the Guide, how do you open Cmd prompt, you said it wouldn't work when it's turned on, how do I access from boot?
    Mine is Local Disk C, so what would I do?
  10. Posts : 72,051
       #79
    Here you go: :)
    Command Prompt at Startup
