Page 16 of 33 FirstFirst ... 6141516171826 ... LastLast
  1. Posts : 72,051
       #150
    antonianus said:
    Each time I try to open an Elevated Command Prompt from Accessories/Command and run as administrator, typing Diskpart no disc info.appears. I am running W7 Version.6.1.7601. Any ideas?
    Ton
    Hello Ton,
    As Ted posted above, it sounds like you may not have typed list disk and pressed Enter at step 4 after typing Diskpart and pressed Enter. :)
  2. Posts : 12
    Windows 7 64bitMicrosoft Windows 7 Home Premium 64-bit 7601 Multiprocessor Free Service Pack 1
       #151
    Brink said:
    Ton
    Hello Ton,
    You are right Shawn, I somehow did not read the article properly and missed
    "typing "list disk". Quite simple simple really and I am much obliged for prompting
    me.
    Many thanks
    Tony
  3. Posts : 72,051
       #152
    You're most welcome Tony. I'm glad that Ted and I could help. :)
  4. Posts : 223
    Hi, I need to do this for my main HDD because it has a rootkit on it, but it won't allow me because it says that you can't perform a clean all on a disk containing the current boot, system, pagefile, crashdump or hibernation volume. That makes sense, but how can I wipe this HDD clean so I can do a clean win7 install?
  5. Posts : 3,133
    Windows 7 Home Premium 64bit SP 1
       #154
    SSD / HDD : Optimize for Windows Reinstallation
    If you have a Windows 7 boot disk, or installation disk, you can boot up into one or the other disks and run Diskpart from there.
  6. Posts : 223
    Thanks.
  7. Posts : 223
    Looks like I'll be using this once again. Can I clean all on my HDD while using my SSD?
  8. Posts : 72,051
       #157
    Hello Robo,
    Yes, you sure can. It will not affect the SSD. :)
  9. Posts : 223
    Thanks, I shortly after remembered that I would have to do it by booting into diskpart since there is a windows 7 install on it. Oh well, thanks anyway and merry Christmas!
  10. Posts : 72,051
       #159
    You're welcome. Merry Christmas. :)
