Page 28 of 33 FirstFirst ... 182627282930 ... LastLast
  1. Posts : 247
    Windows 7 Home Premium 64-bit (OEM)
       #270
    Clean, Clean All, DBAN and C-Cleaner
    Hi Brink,
    Here is what I understood from the thread, adding some assumptions of my own. Can you tell me if this is correct ?
    If you only want to get rid of confirmed or suspected viruses : just use Clean. It is much quicker. Possible viruses will remain on your disk, since Clean does not erase files, but they won't be able to be activated afterwards, ever, even after you've repartitioned the disk and reinstalled Windows, since Clean destroys the data the system needs to find and use those files. (I'm especially unsure of this statement.)
    If you want, on top of that or exclusively, to prevent any third party to recover your confidential data by using forensic software or other techniques, in case you give away your PC, discard the disk or it is stolen : use Clean all. It will overwrite the whole disk, defeating (ordinary) recovery techniques. Viruses, obviously, would be physically wiped as well.
    If you want an even better level of defense against snooping on your data : use DBAN. It does a 3-pass overwrite (or even more).
    All three methods may be used to erase all your disks, including your system disk, provided you boot from an external source (Windows DVD or flash drive, DBAN CD).
    C-Cleaner's wipe function can be adjusted to multiple overwrites, but it's only good for erasing data drives or partitions, since it works from within Windows.
  2. Posts : 72,077
       #271
    Hello Clairvaux, :)
    If you have a virus, then usually wiping the disk completely by overriding it with a few passes should clean it.
    However, there are some viruses out there are pretty stubborn.
  3. Posts : 247
       #272
    Thank you, Brink.
    So, despite the vast difference in the time required, it might be a sound strategy to do a Clean all, or even to apply DBAN, when reinstalling from scratch, just in case one has a virus undetected by one's antivirus ?
    Are you implying that some viruses could escape even a Clean all, or multiple-pass overwrite ?
  4. Posts : 72,077
       #273
    "Clean" is fine since it marks the whole disk as deleted, and the data gets overridden as you use the drive.
    One that get into your BIOS would be one type, but those are rare. You mostly have to worry about reinfecting the PC with say an infected USB that you didn't know about.
    Just always use a good AV program (ex: Malwarebytes) to scan with to help be safe.
  5. Posts : 247
       #274
    Thanks.
  6. Posts : 21,004
       #275
    Hello Shawn I shall try again but I have tried to clean all a 250GB Samsung twice now and I come up with the message in the pic. In the Disk Management the disk is shown as unallocated as I just deleted the volume after seeing this was one way to get the disk cleaned.
    Now does this mean I have trashed to disk or made it impossible for the disk to be cleaned (all) using this tutorial.?
    I am just heading of to bed now as it is getting real late but shall check in the morning to see what has happened.
    Attached Thumbnails Attached Thumbnails Disk - Clean and Clean All with Diskpart Command-chkdsk-1.png
  7. Posts : 72,077
       #276
    Hello John, :)
    Odd, a semaphore timeout error is for when there is a problem with the network or network adapter.
    Is this a network drive?
    Are you able to run the "Clean" command instead?
  8. Posts : 21,004
       #277
    Hello Shawn as far as I know the two drives are not connected to any network.
    What I have done so far I saw that deleting a volume would leave an unallocated space so did that but then it isn't recognized in the machine.
    Currently I have had a 250GB being wiped via Partition Wizard but it ha only got to 19% and it seems to be stuck at that . Would it be because the drive is showing unallocated space??
    Anyway I shall try a straight clean on the smaller drive on my laptop I just want to give these drives to a young fellow and be sure there is none of my personal data left on it - not that I don't trust him more I don't want any scraps left over mucking up his system.
  9. Posts : 200
       #278
    Clairvaux said:
    ...All three methods may be used to erase all your disks, including your system disk, provided you boot from an external source (Windows DVD or flash drive, DBAN CD).
    This is what I was wondering.... How to wipe a "system" drive.
  10. Posts : 72,077
       #279
    Hello Benteke, :)
    Yep, you could boot to a command prompt at boot, then run the "clean" command to wipe the system disk. :)
