Page 33 of 33 FirstFirst ... 23313233
  1. Posts : 1,384
    Win 7 Ult 64-bit
       #320
    DiskPart is fine. I prefers one that's tried and true.
    I've put off formatting that machine and installing Win 7 for months. I think I can face it now. If I turn it into a huge doorstop, and can just put in a different HD.
  2. Posts : 89
    Win 7 x64
       #321
    RoWin7 said:
    You went to my original problem and skipped all the replies, then read my most recent question.
    Yes, and? I fail to see any logics in that sentence.
    Ofc I'll go to your original problem to try and address it. And why not skip all replies in between as there was nothing to say there. I read them and then I read your most recent question and then I gave you a rather reasonable reply. So instead of being thankless try to reason what ppl advise you.
  3. Posts : 81
    Windows 10 Home C1H1
       #322
    My uncle is an accountant and wants to wipe his hard drive as to assure a client that his information cannot be recovered by the irs. Clearly a hammer and sulfuric acid would provide nearly absolute assurance, but are there any free or not free software options i can suggest to him?
    Thanks.
    Joe
  4. Posts : 19,383
       #323
    Thanks.
    Joe
    DBAN
    Darik's Boot and Nuke - Use to Secure Wipe a Hard Drive - Windows 7 Help Forums
  5. Posts : 81
       #324
    Golden,
    I read and acted on your reply in early November.
    I apologize for taking so long to thank you.
    Sincerely,
    Joe
  6. Posts : 4
    Win 7 64bit Home prem
       #325
    piramiter error
    i did all of the top you showed but i got a error of peramitor i saw in another website that i needed to put a drive leter also which is not here but now i cant to a clean i just did a clean all and it took hours to finish im worn out i have been trying to clean this HDD for 3 days now i finally got it with DBAN and thru cmd with clean all i added a pic of what it said all went well till i formated it to ntfs quick
    Attached Thumbnails Attached Thumbnails Disk - Clean and Clean All with Diskpart Command-20180503_215218-1-.jpg
  7. Posts : 4
       #326
    i dont know why this is upside down.....
  8. Posts : 4
       #327
    another error
    first i had a paramiter error after fs=ntfs was done now i get this error after i try to clean the drive kinda start over and all
    Attached Thumbnails Attached Thumbnails Disk - Clean and Clean All with Diskpart Command-20180503_224321-1-.jpg
  9. Posts : 4
       #328
    it said it was healthy also the drive
  10. Posts : 72,063
       #329
    Hello UnKnown4mat, and welcome to Seven Forums. :)
    What type of drive are your trying to run the clean command on?
    Usually this error is an indication of drive failure.
