Log On Screen - Change
Page 9 of 39 FirstFirst ... 789101119 ... LastLast
  1. Posts : 8,375
       #80
    The problem seen with ones like LogonStudio is always rushing back to their 300 page inventory to look over the limited selection there. You must download from there! You know what I say to that don't you?!
    (or maybe you wouldn't want to!)
      My Computers
  2. Posts : 179
    windows7 7100 x64
       #81
    night hawk your right this way i can use what i want.
    ok it took a bit longer as the original pic i decide on was to big in size(pixels and KB)but after a little bit of work it looks really good.
  3. Posts : 72,058
       #82
    murphy25 said:
    sorry about the questions.
    and i agree this method is best ive had trouble with logon changers before but this worked flawlessly.
    Murphy,
    Don't be sorry about any questions. That's what we're here for. :)
  4. Posts : 72,058
       #83
    HKeleher said:
    You are correct Brink, I didn't know that. However it's easy to put back (just run the tool again and change it back.) I don't change my themes often... if ever, so it's not a big deal to me but if I did change themes alot this would not be viable and I would prefer a more permanent change. It's possible they will make changes to the app that will make it more permanent, who knows? Only they do I guess, heheh.
    And yeah, StudioLogon... I never was a fan.
    The important part is that your happy with it. :)
  5. Posts : 8,375
       #84
    This was a great find premature of the actual working feature that will be seen in the RTMs as time goes on. Ever get sick of that same old splash screen or wish to put something like a family photo in place the usual? Now you can do it without fuss or worry!
    The download will see the new entry creates for you with a simple double click on that. The sub folders still have to be manually created at times however to insure those are there.
      My Computers
  6. Posts : 22,814
    W 7 64-bit Ultimate
       #85
    Hello again Murphy.
    Asking questions in this tutorial is OK, Brink was just pointing out that there's a thread to post pics of the logon screens that people are using, you can access it at the link below.
    Post your Start-up screen
    Later Ted
  7. Posts : 179
    windows7 7100 x64
       #86
    just posted mine well the pic i used its a bit annoying i couldnt take a proper screeny of it though could u do it in vista as i know i could in xp but i bypassed vista altogether so wouldnt know?
  8. Posts : 2,588
    SEVEN x64
       #87
    Hi Shawn..... i gotta a little problem sorting the boot screen out
    i followed the instructions & ended up here
    the ''info'' & ''backgrounds'' folders did not exist, the default image was just sitting in the ''oobe'' folder....so i created the said folders, placed the desired image in there along with the default, but it has not changed...
    i must have taken a wrong turn.....
    :)SK
  9. Posts : 18,404
    What's the size of the pic Skunk? It has to be less that 256kb in size to work.
  10. Posts : 2,588
    SEVEN x64
       #89
    yep, she only weighs in at about 34kb .......
    :)SK
