Windows DVD Maker - How to Use
Page 3 of 4 FirstFirst 1234 LastLast
  1. Posts : 72,049
       #20
    Please run winver, and post a screenshot to see if you do. :)
    About Windows - Open
  2. Posts : 10
    Windows 7 Home Premium 64-bit
       #21
    here...
    what that error means?
    Last edited by Brink; 01 Sep 2013 at 10:22. Reason: merged and removed unneeded quote of entire tutorial
  3. Posts : 72,049
       #22
    Rissa,
    You have Windows 7 Home Basic that does not include Windows DVD Maker. You will not be able to download or install it.
    Windows DVD Maker is only available in the Windows 7 Home Premium, Professional, Ultimate, and Enterprise editions.
  4. Posts : 10
       #23
    why the audio did not play?
  5. Posts : 72,049
       #24
    Hello Rissa,
    I'm not sure what you mean. If you still have Windows 7 Home Basic like in your screenshots above, then you do not have Windows DVD Maker.
    If you upgrade to Windows 7 Home Premium from your specs, then you might double check to see if you may have made a mistake while creating it.
  6. Posts : 10
       #25
    Brink said:
    Hello Rissa,
    Im using windows 7 home premium now.. when i play the dvd id dvd player there is no sound...
  7. Posts : 72,049
       #26
    Double check to see if you may have made a mistake. Possibly wrong format used.
    Did it play when testing before burning the DVD?
  8. Posts : 10
       #27
    is .avi format possible?
  9. Posts : 72,049
       #28
    Sure, that's fine for a video or media file. I'm afraid that I don't have enough experience with this to give better support on other than play with a bit more, and test it before burning to a DVD.
  10. Posts : 1
    Windows 7 Professional 64 bit
       #29
    Windows DVD Maker not playing audio files
    I'm trying to create a DVD with Windows DVD Maker. I have uploaded my pictures, videos and audio files. When I preview my DVD it plays music when the menu comes up but never plays any song audio during the photo sequences. On the screen to Add Music to Slide Show I have 3 songs listed (in mp3 format). It gives a total of time for the length of music 10:43; and under that it says length of slide show 00:00. But where the photos and videos are listed it says 31 of 150 minutes in the bottom left hand corner. I don't understand what I'm doing wrong?
