Taskbar Pinned Programs - Enable or Disable
  1. Posts : 32
    ok....it solved. But i just add the string value name IsShortcut in WSFILE key (HKEY_CLASSES_ROOT\WSHFile) and i can make a pin in the taskbar again. But in lnkfile key i keep to remove IsShortcut value for remove the arrow from the shortcut icon.
    Many thanks to you Brink...But i still have more question about folder sharing in windows 7, where i can post it?
  2. Posts : 72,130
    You're most welcome Crossnet. I'm happy to hear that you got it sorted. :)
    Folder sharing issues can be posted in the "Network & Sharing" forum area.
  3. Posts : 32
    Brink...how i did not got any problem with taskbar pin for six month ago although i remove the icon arrow?
  4. Posts : 72,130
    Hello Crossnet,
    I suppose it depends on the program or method it/you used to do so. Usually when you removed the IsShortcut entry (improper XP method for Windows 7) in the registry, the results are immediate. I'm just happy that you got it sorted.
  5. Posts : 5
    Windows 7 Home Premium 64-Bit
       #14
    An additional thing to check in the registry: Go to "HKEY_CURRENT_USER\Software\Policies\Microsoft\Windows\Explorer". If "NoPinningToTaskbar" exists there, delete it.
  6. Posts : 72,130
       #15
    Hello Mike, and welcome to Seven Forums.
    Thank you. It had been added to the REG files to helps others that may have it. :)
  7. Posts : 5
       #16
    Happy to help save some time for someone in the future.
  8. Posts : 43
    win7_home_64
       #17
    Enable Pinning again
    In our company this policies are in place:
    [HKEY_CURRENT_USER\Software\Policies\Microsoft\Windows\Explorer]
    "NoPinningToTaskbar"=dword:00000001
    "TaskbarNoPinnedList"=dword:00000001
    I tried the following RunKeys with this line:
    "C:\Windows\regedit /s C:\_D\sources\pc\registry\pin.reg"
    where pin.reg has set both values = 0.
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Run]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\Run][HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\RunServices][HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\RunServices]
    I also tried with a task at "System StartUp"
    When I log on or restart the machine the keys are set OK, but the pinning is only possible after a new/next LogOn.
    So where should I place the "C:\Windows\regedit /s C:\_D\sources\pc\registry\pin.reg" or what else do I have to do, to have the pinnend elements already at the first LogOn
  9. Posts : 72,130
       #18
    Hello 5ggggg,
    You could also create a .bat file to do this, and have the .bat file restart explorer instead of having to log out/in or restart. This way you could have the .bat file run at startup instead. :)
  10. Posts : 43
    win7_home_64
       #19
    THX, how to kill / restart the exploerer ?
