Folder - Delete from Command Prompt
Page 6 of 11 FirstFirst ... 45678 ... LastLast
  1. Posts : 16
    windows 7 ultimate x64
       #50
    tried that before joining here didnt fix either
  2. Posts : 72,062
       #51
    Please go ahead and post a screenshot showing this folder on your desktop to see if it may help ID a cause. :)
  3. Posts : 16
       #52
    you want a screenshot of my desktop ? its just a folder sitting on my desktop, had pictures in it for a soccer game i play online, i went to the forum where i downloaded the file and others have said they cant delete it either...hmm
  4. Posts : 72,062
       #53
    The screenshot was to determine if it may have been a folder added by the system or not.
    Since it's not, see if you are able to open it. If so, delete the contents from inside the folder first, then see if you are able to delete the folder.
  5. Posts : 16
       #54
    it says cannot find the item, this is no longer located in C:\Users\Rob\Desktop\this folder when i try to delete the folder
  6. Posts : 72,062
       #55
    In that case, I'd also contact the forum where you got it from to see if they may have a solution since others have the same issue with their download.
    As a test to see if this may reset it, right click on your desktop and click on View -> Auto arrange icons to toggle it on and off.
  7. Posts : 16
       #56
    i have done, they got nothing thats why im searching myself, and the view icon thing didnt work either
    appreciate your help
  8. Posts : 72,062
       #57
    Ok. Let's see if deleting the two hidden desktop.ini files on your desktop, and restarting the computer afterwards will remove this ghost folder then. If there's a reference entry in one of the desktop.ini files for this folder, then this should clear it.
    You'll need to first temporarily set Windows to show hidden OS files using step 5 in OPTION ONE of the tutorial below.
    Hidden Files and Folders - Show or Hide
  9. Posts : 16
       #58
    ok i always have show hidden files selected anyway, where would the desktop.ini be ?
  10. Posts : 16
       #59
    sorry i deleted them, but didnt do anything still cant delete it
