Folder - Delete from Command Prompt
Page 9 of 11 FirstFirst ... 7891011 LastLast
  1. Posts : 7
    Windows 8 64 bit
       #80
    I meant my entire problem, not just the use of an elevated command prompt.
  2. Posts : 3
    Windows 7 Home Premium 64 bit
       #81
    I don't know if I'm doing it right.It just says:
    The system cannot find the file specified.
    I followed you're instructions correctly. Am I doing something wrong? I also used a elevated command prompt, but it still gives me the same response.
  3. Posts : 72,055
       #82
    Were you able to delete the two folders using an elevated command prompt?
    If not, then yes please give full details.
  4. Posts : 72,055
       #83
    Hello MLBFalcon, and welcome to Seven Forums. :)
    Did you use the correct full path of the folder?
    Which option are you using? If you are using a command prompt at boot, the drive letters are not always the same at boot as they are in Windows.
  5. Posts : 7
    Windows 8 64 bit
       #84
    Well, this folder is extremely stubborn. Here is my process and sorry for the length of this post:
    I tried deleting it first.
    It failed.
    I then tried using a command prompt to delete it.
    That failed too.
    I created a batch file; one that was recommended to someone with a similar issue to me.
    This one did not work.
    I decided to break out the big guns: the elevated command prompt.
    Nope, still there.
    What do?
  6. Posts : 72,055
       #85
    Stubborn indeed. If you like, see if the free program Unlocker may be able to delete it.
  7. Posts : 7
    Windows 8 64 bit
       #86
    Hey guys, guess what.
    Didn't work either.
  8. Posts : 72,055
       #87
    If you click on Yes in the second screenshot, does it delete it for you then?
  9. Posts : 7
    Windows 8 64 bit
       #88
    Nope, still here after reboot.
  10. Posts : 72,055
       #89
    See if you are able to rename the "New Folder" folder, and be able to delete it afterwards.
    If not, see if you are able to delete the contents of the folder, then see if you are able to delete the folder.
    If still not, take ownership of the folder, and see if you are able to delete it afterwards.
    Take Ownership Shortcut
