Start Menu - Add Run Button
    How to Add the Run command Button to the Windows 7 Start Menu
    METHOD ONE
    Through the Start Menu
    1. Open the Start Menu.
    2. Right Click on a empty space on the Start Menu and select Properties.
    3. Click on the Start Menu Tab and click on Customize.
    4. Tick the Run Command and OK.
    METHOD TWO
    Through the Local Group Policy Editor
    2. In the left pane, click on User Configuration, Administrative Templates and Start Menu and Taskbar. (See screenshot below)
    3. In the right pane, right click on Add the Run command to the Start Menu and click on Edit.
    4. To Add Search Internet Link to Start Menu
    A) Dot Enabled and click on OK.
    B) Go to step 6.
    5. To Disable Add Search Internet Link to Start Menu
    A) Dot Disabled or Not Configured and click on OK. (See screenshot below)
    B) Go to step 6.
    6. Close the Local Group Policy Editor window.
  1. Posts : 1,633
    Win 7 Ult SP1/Win 10 Pro (all x64)
    I think the run command is enabled by default isn't it? It was on mine anyway...thanks.
  2. Posts : 748
    Vista and now 7 in 32 and 64 bit.
    I believe you are right, Ex-Brit. Once again, my installation is so heavily customised that I don't know, but the Run is certainly ther in All programs. The Tutorial , I think, refers to the one in the black, right hand panel. Maybe one or the other will be excluded from the final release, as it would be superfluous.
  3. Posts : 1,633
    You may be right. It's early days yet.
  4. Posts : 748
    Update. I have just done a reinstall of 7 without customisation. (I love to punish myself)
    There is a Run by default, but it is tucked away in accessories. I must have moved mine to the general program list myself. So the tutorial would be a help for people starting out on 7.
  5. Posts : 1,633
    LOL...well at least this will help those that can't find it. Thanks Dave.
  6. Posts : 6
    windows 7
    It was helpful... I did clean install yesterday.. Run command was not added as default.
    I was using Ctrl+R shortcut to launch it! always good to have the button!
