Windows 7: Microsoft Mangement Console - Create Custom MSC
How to Create a Custom MSC in Microsoft Management Console in Windows
Published by Brink
18 Jan 2010
information   Information
This will show you how to add MSC snap-ins of your choice (ex: gpedit.msc and compmgmt.msc) in the Microsoft Management Console to then save it as a custom MSC file to always open this file with the added snap-ins included in Vista, Windows 7, and Windows 8.
You can place this custom.msc file where you like for easy use, or create a shortcut of the custom.msc file (if saved at C:\Windows\System32) to use the shortcut where you like instead.
Note   Note
The settings below will be remembered when you save your custom MSC console, and each time you close it afterwards.
  • Column widths
  • Action pane (off/on)
  • Default opening location/position
  • Window size
If you decide you do not want the custom MSC file you created using this tutorial at a later date, then you can always just delete it like any other file without any problems doing so.
EXAMPLE: Custom MSC File
NOTE: For example, I created a custom MSC file that has the gpedit.msc (Local Group Policy Object Editor) and compmgmt.msc (Computer Management) snap-in added in one MSC console. The custom MSC file will open with these two snap-ins, or the ones you added, always included.
Here's How:
1. Press the Windows + R keys to open the Run dialog, type mmc in the search box, and press Enter.
2. Click/tap on File (menu bar) and Add/Remove Snap-in. (see screenshot below)
3. In the left pane, select the msc snap-in (ex: Computer Management) you want to add, and click on the Add button in the middle. (see screenshot below)
4. If you get option dialog windows for the snap-in, then you can set them to how you like, and click/tap on Next, OK, or Finish until finished. (see screenshots below)
NOTE: Each snap-in will have it's own set of options.
5. Repeat steps 3 and 4 until you added all of the snap-ins that you want in the right pane for this custom MSC file. For example, I wanted to add gpedit.msc (Group Policy Object Editor) as well. (see screenshot below)
6. When done, click/tap on OK. (see screenshot above)
7. Click/tap on File (menu bar) and Save As. (see screenshot below)
8. Navigate to where you want to save this custom .msc file to, type in a name for it, and click/tap on Save. (see screenshot below)
9. You now have a custom MSC file that you can click on to always open a management console with the snap-ins you added for it. Move it to where you like for easy use.
NOTE: You could also Pin to Taskbar or Pin to Start Menu this MSC file.
18 Jan 2012   #1
lehnerus2000
Hi Brink
You could probably mention that you can also configure:
  • The column widths.
  • The Action pane (off/on).
  • A default opening location
  • An overall window size.
These settings will be remembered when you save your custom console.
That came up in this thread (well I suggested it as a solution):
mmc windows display problem
18 Jan 2012   #2
Brink
64-bit Windows 10 Pro
Thank you Lehnerus. Added. It also remembers them for when last closed as well. :)
18 Jan 2012   #3
lehnerus2000
Quote   Quote: Originally Posted by Brink View Post
No problems (and thank you for writing so many good tutorials in the first place). :)
It just came up on mickey megabyte's thread and when I checked to see if I needed to write a tutorial, I found your one.
It's easy to forget a small detail (or two) when writing instructions.
Although I have only posted 2 (official) tutorials, I am still paranoid that I've forgotten something important/obvious.
Until I authored mine ("Computer Management") it would always start with the Action pane on and at a small size (i.e. it never remembered how I left it).
18 Jan 2012   #4
Brink
Quote   Quote: Originally Posted by lehnerus2000 View Post
Strange. I created a Computer Management MSC and saved it to the desktop. Each time I open the custom MSC, make changes to it's size, position, etc... and closed it, it would open the same way next time. At least for me it does.
18 Jan 2012   #5
mickey megabyte
ultimate 64 sp1
it doesn't for me - it opens at the size it was at the last save.
but then again, mine are mucked up somehow anyway! :)
18 Jan 2012   #6
lehnerus2000
It is weird
I meant the default "Computer Management" console.
Unless I choose "Author", I don't get the "Save" option.
Even using "Author" mine won't remember to open showing "Services".
It will remember other choices that I've tried.
I have mine set to open to "Device Manager" instead.
Note:
I haven't tried every possible option though.
I guess it's just like how some people have trouble with certain programs and others don't (e.g. AV programs, Firefox, etc.).
I guess some weird combination of settings and/or software is responsible.
18 Jan 2012   #7
Brink
Ah, ok. I get the same as you with that as well. It's only when I create a custom MSC from the tutorial for it when it is remembered.
I've never had "Author" do anything different for me though.
Microsoft Management Console is down
I get an error message saying the MMC is not working. I found Step-by-Step Guide to the Microsoft Management Console but could only get to step 6. I says Click Finish. This returns you to the Add/Remove Snap-ins dialog box. Click Close. but there is no CLOSE button on the screen. Then in step 7...
General Discussion
Screenshot in Mangement Console and Partition Recovery Wizard
Is it possible to take a screenshot while using Management Console in command prompt of Startup Repair, or Partition Recovery Wizard from the Mini-Tool Partition Magic bootable disk? My computer will not boot due to a 0x490 boot error. Is a Windows 7 bootable file necessary to screenprint?
General Discussion
Hi Shawn. Somebody told me today that Microsoft Management Console was something cool that I should look at. So I looked at it. It appears you launch it by opening a Command Prompt (I suppose it should be elevated but I didn't use one) and entering MMC. I am thinking that's equivalent to...
General Discussion
Microsoft Management Console - Unavailable
Hi, I am trying to access the microsoft management console using the only account set up on the PC, ie, an admin account. However, I am getting a message indicating it is either unavailable or I do not have access rights. Are there any known issues with accessing this ? Thx for any help...
General Discussion
Twitter Facebook
