Virtual Hard Disk - Create and Attach VHD
Page 3 of 9 FirstFirst 12345 ... LastLast
  1. Posts : 12,364
    8 Pro x64
       #20
    Thanks Shawn, I went with the create vdisk option during installation and it's all good.
    However is it normal to have to attach a VHD after each boot? Is there anyway for it to automatically load on start-up?
  2. Posts : 72,062
       #21
    While attaching a VHD through Disk Management will not add it to the boot files, I'm not certain as to why you had to keep attaching it though.
  3. Posts : 12,364
    8 Pro x64
       #22
    That's why I was a little confused. I followed the tut and it attached fine through both disk management or the command prompt, but it didn't want to stay attached after a re-boot
  4. Posts : 72,062
       #23
    You might see if using a different drive letter for the VHD may make a difference.
  5. Posts : 12,364
    8 Pro x64
       #24
    I deleted that original vhd and created one during installation, but even the new vhd with 7264 installed doesn't show up attached within 7100.
    I changed the drive letter and even created a new test vhd in the cmd prompt and that doesn't attach automatically either
    EDIT:
    I just attached the two existing vhd's and even created a new one from within 7201 and they still disappear after a re-boot
  6. Posts : 72,062
       #25
    That is strange. I must admit that I am stumped as to why is does that whenever you reboot.
  7. Posts : 12,364
    8 Pro x64
       #26
    This sounds like the return of the Beta Breaker
  8. Posts : 72,062
       #27
    Indeed.
    Be sure to send feedback on it.
  9. Posts : 1
    windows 7 rc
       #28
    vhd
    im having the verysame problem i create a perfect RECOVERY(D:)\ CREATE ME A NEW SYSTEM IMAGE .BACKUP MY SYSTEM AND EVERYTIME WINDOWS UPDATE NEEDS TO REBOOT TO FINISH THE INSTALATION MY VHD IS HISTORY HAVE TO GO REATTACH IT that gets a little old its shure fluttstrating i would like to know the trick on keeping it mounted permanatly running out of options
    Last edited by johnny66; 05 Aug 2009 at 10:17. Reason: found someone having the same problem
  10. Posts : 13
    Windows 7 Ultimate 7600
       #29
    Hiya guys...
    I am trying to create a VHD so I can trial win7x64 and I have hit a virtual wall....
    So far I have followed the tut and created the VHD file and now it doesn't show up in computer management...
    I have looked at where I placed the .VHD file and its there but nothing showing up at all...
    Have I missed something?
