Virtual Hard Disk - Create and Attach VHD
Page 4 of 9 FirstFirst ... 23456 ... LastLast
  1. Posts : 2
    i have got the same issue here, i created VHD but when i reboot the system i does not show it again. any ideas ???
    by the way i am using the final release of windows 7 RTM build 7600.
  2. Posts : 72,052
       #31
    Hello Cyborgee, and welcome to Seven Forums.
    Where do you have the VHD file save at?
    Was this VHD created using the method in the tutorial or another program?
    UPDATE:
    It seems to be either a new feature or bug in the final RTM build. Any attached VHD (newly created or existing) will no longer be attached after a restart. It seems to only be a temporary feature per active session now. I have added a warning at the top of the tutorial.
  3. Posts : 2
    Thanks Brink
    well , i made the VHD by using the same method in the tutorial. and i save it on drive C , system partition.
    I went through many blogs about creating VHD. and i have found that most of them has the same issue. but i found that one of them mentioned that in order to have a bootable VHD then you have to create it by using setup CD (repair command) , and using certain commands to create it. after that install the operating system directly without rebooting.
    i will try this to install windows 2008 R2 which has the same tools as windows 7, and i will inform you about it.
    But it is important to have a VHD that starts while windows 7 booting without installing an operating system.
  4. Posts : 72,052
       #33
    Cyborgee,
    Oh, well if you wanted to be able to boot from a VHD with a OS on it like normal, then this will help show you how to.
    Virtual Hard Drive VHD File - Create and Start with at Boot
  5. Posts : 1
    Windows 7 Professional 64-bit Operating System
       #34
    NOOB question
    My boss got me a new Windows 7 box and wants me to create Virtual Machines running either Windows Server 2008 or Windows Server 2005. I have used MS Virtual Server 2005 in the past, but with Windows 7, I can't install the applicatioin, I get a "hard block" or whatever the terminology is.
    Anyways, I followed the awesome tutorial above, and have created a VHD on my box, but was wondering how I would go about installing another OS to it, is that even possible with the available functionality? I have done my best to research this topic, but plead ignorance because I can't find any tutorials in regards to installing a "non windows 7 OS" as a virtual machine on a windows 7 machine....
    And yes, as I was typing all this, I stumbled upon my answer... fmylife, but thanks guys for adding to this awesome forum!
    Windows Virtual PC - Create Virtual Machine
  6. Posts : 72,052
       #35
    Hello Gazhalim,
    LOL, I'm happy to hear that you got it sorted. :)
  7. Posts : 1
    7
       #36
    Same isuue here.
    Spice Boy said:
    Hiya guys...
    I am trying to create a VHD so I can trial win7x64 and I have hit a virtual wall....
    So far I have followed the tut and created the VHD file and now it doesn't show up in computer management...
    I have looked at where I placed the .VHD file and its there but nothing showing up at all...
    Have I missed something?
    Hi. Ive followed your steps but when i look inside or double click the hard drive theres nothing inside and nothing happens.
    I attached an image created by W7 of a backup and i was hoping this tut might help but the only thing i see its an empty 180G space.
    If some could help would be greatly appreciated.
    Attached Thumbnails Attached Thumbnails Virtual Hard Disk - Create and Attach VHD-vhd.jpg
  8. Posts : 72,052
       #37
    Hello Chulojay, and welcome to Seven Forums.
    If this VHD is of a Windows 7 system image backup, then this might help instead to attach it.
    System Image - Extract Files Using Disk Management
  9. Posts : 341
    W7 Ult x64, W8 Pro x64 and W10 Pro x64
       #38
    I followed the steps(I think) but the VHD created does not have anything in it. Is this what is supposed to be?
  10. Posts : 72,052
       #39
    Hello Churin,
    If you created a new VHD, then yes it would be empty. It's just like creating a new partition or volume. :)
