How to Create a "Screen Saver Settings" Shortcut in Vista, Windows 7, and Windows 8
This tutorial will show you how to create or download a Screen Saver Settings shortcut for Vista, Windows 7, and Windows 8.
EXAMPLE: Screen Saver Settings
OPTION ONE
To Download a "Screen Saver Settings" Shortcut
1. Click/tap on the Download button below to download the file below.
Screen_Saver_Settings.zip
2. Save the .zip file to your desktop.
3. Open the .zip file and extract the Screen Saver Settings shortcut to the desktop
4. Right click on the
Screen Saver Settings shortcut, and click/tap on
Properties,
General tab, and on the
Unblock button. (See screenshot below)
5. In
Vista or
Windows 7, you can now
Pin to Taskbar (Windows 7) or
Pin to Start Menu, add to
Quick Launch,
assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
6. In
Windows 8, you can
Pin to Taskbar on desktop,
Pin to Start screen, add to
Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
7. When finished, you can delete the downloaded .zip file if you like.
OPTION TWO
To Manually Create a "Screen Saver Settings" Shortcut
1. Right click or press and hold on an empty area on desktop, and click/tap on
New and
Shortcut. (See screenshot below)
2. Type the command below into the location area, and click/tap on the
Next button. (See screenshot below)
rundll32.exe shell32.dll,Control_RunDLL desk.cpl,,1
3. Type
Screen Saver Settings for the name, and click/tap on the
Finish button. (See screenshot below)
4. Right click on the new
Screen Saver Settings shortcut on the Desktop, and click/tap on
Properties.
5. Click/tap on the
Shortcut tab, then click/tap on the
Change Icon button. (See screenshot below)
6. In the line under "Look for icons in this file", type the location below, and press
Enter. (See screenshot below)
%windir%\System32\themecpl.dll
7. Select the icon highlighted in blue above, and click/tap on
OK. (See screenshot above)
NOTE: You can use any icon that you would like instead though.
8. Click/tap on
OK. (See screenshot below)
9. In
Vista or
Quick Launch,
10. In
Windows 8, you can
