#40
Hello MS,
You might see if setting Adobe as the default program again, or reinstalling it may set the icon back to using it's default.
Hello MS,
Some programs will not let you change the default icon since they override it with their icon instead.
Great write up... This program has eluded me for years and finally discovered it again!
Yeah, it's a pain, but you can always use a Resource Editor (IE: ResEdit, Resource Tuner, Restorator, ResHack, etc.) to modify the executable, this doesn't always work either.
P.S.
Shawn, I would like to contact you, privately, regarding an issue.
I followed the guide, but the changes don't last. The icon keeps reverting back to the original icon (Foobar version). I've tried using the downloaded program and manually editing it. I'm trying to change to the Windows 7 default icon.
Hello Chaoz,
From your duplicate post (now removed), you could download and merge the .reg file for the listed .mp3 option in the tutorial below to restore it's default associations to hopefully fix it's default icon as well.
Hope this helps, :)
Thanks Brian
I registered in this forum only to thank you. The regedit method works perfectly
After I tried the regedit method and saw it works, I downloaded the program, and it is fantastic.
It is really free, no advertising, no toolbar. Free.
Thanks again.
This was my impression too and I hated Notepad++ default icon which applied to all txt, ini, xml, etc, files associated with it. But found a way here to over-ride the programs icon (which should work for other programs too):
Then add an expandable string value (REG_EXPAND_SZ) with the desired icons address. In my case, I used %SystemRoot%\system32\imageres.dll,-102 which is the default notepad icon. Worked fine.File association default icon
You can override the icon for example by adding this registry key:
HKCU\Software\Classes\Applications\notepad++\DefaultIcon
