#70
hi
yesterday i used a software to calibrate my monitor and x-rite photo calibrator and when i uninstalled it , it did a mess up
are there default screenshots about windows 7 Color Management ?
i did a mess up even on my windows 8.1 , but i guess the default are the same
thanks
Hello Drugo,
If you like, you should be able to run the Display Color Calibration in Windows to see if it may be able to correct it for you.
Hi Brink
but the hardware system is really more accurate then the display color calibration in windows
i 'm looking for default settings of windows 7 color management (a clean install), like this (but i don't think they are default the screenshot) above
http://www.timelessme.com/temp/posti...n7Issue_01.jpg
thanks
The default is based off of your monitor and graphics card, so it will not always be the same from system to system. About all you can do is run the calibration again until you have it set how you like.
Doing a system restore using a restore point dated before you did the calibration will undo it for you though.
