Window Color and Appearance Shortcut - Create
    How to Create a "Window Color and Appearance" Shortcut
    This will show you how to create or download a Window Color and Appearance shortcut that opens directly to Advanced appearance settings.
    EXAMPLE: Advanced Window Color and Appearance
    Window Color and Appearance Shortcut - Create-window_color_and_appearance.jpg
    OPTION ONE
    To Download the "Window Color and Appearance" Shortcut
    1. Click on the Download button below to download the file below.
    Advanced_Window_Color_and_Appearance.zip
    2. Click on Save, and save the .zip file to the desktop.
    3. Open the .zip file and extract the Window Color and Appearance shortcut to the desktop.
    4. Right click on the Window Color and Appearance shortcut, and click on Properties, General tab, and on the Unblock button. (See screenshot below)
    5. You can now Pin to Taskbar or Pin to Start Menu this shortcut, assign a keyboard shortcut to it, or move it where you like for easy use.
    6. When done, you can delete the downloaded .zip file on the desktop if you like, or save it to use again.
    OPTION TWO
    To Manually Create the "Window Color and Appearance" Shortcut
    1. Right click on a empty area on desktop, and click on New and Shortcut.
    2. Copy and paste either command below into the location area, and click on the Next button. (See screenshot below)
    rundll32.exe shell32.dll,Control_RunDLL desk.cpl,,5
    OR
    %windir%\System32\rundll32.exe shell32.dll,Control_RunDLL desk.cpl,Advanced,@Advanced
    3. Type Window Color and Appearance for the name, and click on the Finish button. (See screenshot below)
    4. Right click on the new Window Color and Appearance shortcut on the Desktop and click on Properties.
    5. Click on the Shortcut tab, then click on the Change Icon button. (See screenshot below)
    6. In the line under "Look for icons in this file", copy and paste the location below and press Enter. (See screenshot below)
    %windir%\System32\themecpl.dll
    7. Select the icon highlighted in blue above and click on OK. (See screenshot above)
    NOTE: You can use any icon that you would like instead though.
    8. Click on OK. (See screenshot below)
    9. You can now Pin to Taskbar or Pin to Start Menu this shortcut, assign a keyboard shortcut to it, or move it where you like for easy use.
  1. Posts : 12
    Windows 7 64 bit
    Wow, your link's string is rather complex. How can anybody remember that.
    I did some research for this and found that it is much easier and thought I would share it with you.
    There is an easier version of this command:
     c:\windows\system32\desk.cpl ,5
    Or in Windows | Run, you can just type in
     desk.cpl ,5
    I am not sure how you figured out that big, long, ugly rundll.exe line. While it works, it is not going to be something you will remember very easily.
    So I decided to share with the next guy who hits this link the shorter version.
  2. Posts : 72,049
    Hello Rhyous,
    Thank you for an alternative option. The only downside to using either of those commands instead of the one in the tutorial is that you do not have a "Pin to taskbar" option in the context menu, and you have to press and hold "Shift" and right click to see the "Pin to Start Menu" option. Another downside is that you cannot drag and drop it on the taskbar as it's own separate pinned icon since it will only be pinned inside the Control Panel icon's jump list instead.
    If that is not a need or concern for the user, then it's a great alternative.
    Thank you again. :)
  3. Posts : 12
    Windows 7 64 bit
    That is a good to know. I never really thought about pinning it.
    I am more of a fan of launching things from Start | Run or making my own Toolbars than I am a fan of using the pinning feature.
  4. Posts : 72,049
    That's true. Pinning is good only for those items that you always use instead.
  5. Posts : 38
    Windows 7/ Ubuntu
    Thank you so much! I am constantly needing this desktop shortcut because I am picky about my fonts, and going into the personlization settings constantly is a PITA; especially when you have 100's of pictures set in your wallpaper folder. Why couldn't Windows leave the Desktop settings alone?
    BTW, when you first create the shortcut you may not be able to pull up the properties with a right click. I believe this is more Windows security crap. I am always in Admin mode and have no UAC. What I had to do was use "Unlocker" v.1.88 (google it) on it first. (Higher versions don't work for unlocking security.) Install Unlocker, right click the Appearance shortcut and "Unlock" it. Keep "no action" selected and press OK. It simply removes the restriction temporarily. Keep Unlocker around because it's very handy.
    I also changed my "Open In" setting to C:\ in stead of C:\Windows\system32 just in case, because Windows really hates it when you mess with system32.
    I like the tip about Run>>desk cpl ,5. After the first run, I can just type "d" into the run dialogue and pull the settings right up too!
  6. Posts : 72,049
    You're most welcome Melaney. :)
    It would be best though to have the "Open In" set as the default C:\Windows\system32 since that is the location of the dll files referenced in the location.
  7. Posts : 23
    Windows 7 Home Premium (64-bit)
    Shawn, although this posting is rather old I do have a quick question. I would like to execute this through the context menu. What data should I input for the command? Thank you very much for your help. I'm sure your a busy busy man, answering all our questions =P Thank You again!
  8. Posts : 72,049
    Hello Brandon,
    Here you go. Fresh out of the oven. :)
    Advanced Window Color and Appearance - Add to Desktop Context Menu
  9. Posts : 186
    Windows 7 Professional 32bit SP1, Windows 10 Home 64-bit at the moment
    I'm new to this forum.
    Over the years I've used all versions of Windows made 3.1/95/98SE/ME/2000/XP/Vista. I'm relatively new to Win7 even though I've used it at work for a couple of years but everything is locked by admin so you can change virtually nothing.
    Thanks for the tip on changing Advanced Window Color and Appearance but can get the same option if you Control Panel\Appearance and Personalization\Personalization\Window Color and Appearance and click Advanced Appearance Settings... and it shows the same options as the downloaded shortcut.
    There are alot of annoying features of Win7 which I hate. I will search this forum for solutions and if nothing if found I'm afraid I will be putting my Vista Home Premium 32bit back even though there are annoying features on there but all the thing I use on Windows still work on it.
