#20
I have home premium x64 and there is a switch user option on the shutdown button options which works just fine.
Hello Kado,
Correct, the Windows 7 Home Basic, Home Premium, Professional, Ultimate, and Enterprise editions all have this in Start Menu as well. This is just so that someone can have a separate shortcut to use instead. For example, to pin it to the taskbar, or use on the desktop.
Mmm yes I see your point. If home premium doesn't have tsdiscon I wonder how it does it and whether one could tap into that to do something similar.
KADO
You can do the "Before" section in the tutorial to download a copy of the tsdiscon.exe file to use in Windows 7 Basic or Home Edition for the shortcut to work afterwards. :)
Thanks for the info Brink. I think for the present I will just stick with the three click method. I don't do it that often.
hi
I just tried Option 1, the switch user shortcut but it's a broken link, then i tried to create one manually, however when i right click and click new shortcut nothing happens. There is no input field.
