Sleep Shortcut - Create
Page 3 of 3 FirstFirst 123
  1. Posts : 1,364
       #20
    Shawn - thx for reply ...
    MourningStar said:
    What I want is a pure standalone Sleep shortcut that I can pin to the taskbar, while leaving all else as is.
    I stumbled across the attached late last night - it works and meets my requirements(quoted above) thus far. I was hoping if you or someone is able to dissect it, show us how it does what it does and relay any 'concerns' if warranted.
    -thx
    Sleep Shortcut - Create Attached Files
  2. Posts : 72,051
       #21
    Thank you for sharing. It scanned clean with Windows Defender.
  3. Posts : 1,364
       #22
    Your welcome. I simply made a shortcut from the .exe via r-clik context menu's Create shortcut. So, will this qualify as a 'Method Three' for this topic?
  4. Posts : 72,051
       #23
    I'll give it some more time to make sure it's safe first since it is an .exe file from an unknown source.
  5. Posts : 1,364
       #24
    fyi, the attachment contains a text file with author contact info.
  6. Posts : 16
    Windows 7 Pro x64
       #25
    -thx
    I uploaded your Sleep.ZIP file to virustotal.com. The resulting report has 2 hits which state it could be "W32/Symmi.AJ.gen!Eldorado" infected, whatever that is. I don't know if this is correct or not. virustotal.com is a free service which uses 57 different virus scanners. These could be just false positives. However, since the report is not clean, I cannot use this file. I just wanted to give anyone who is thinking about using this file a friendly warning.
    I used the create shortcut method first using the command:
    C:\Windows\System32\rundll32.exe Powrprof.dll,SetSuspendState
    and then:
    C:\Windows\System32\rundll32.exe Powrprof.dll,SetSuspendState Sleep
    Because I have Hibernate enabled, using the shortcut put my computer into Hibernation mode instead of sleep. Unless you turn off Hibernation, you cannot use a simple shortcut to put your PC to sleep. I guess Microsoft just wanted to make things harder for us.
  7. Posts : 72,051
       #26
    It a false positive.
    The file is nothing more than a shortcut that runs a .vbs file, and both are 100% safe and clean. Here's the contents of the .vbs file below.
    Dim objShell
    Set objShell = CreateObject("Shell.Application")
    objShell.ShutdownWindows
    set objShell = nothing
    Set WshShell = CreateObject("WScript.Shell")
    WshShell.SendKeys "{Enter}"
    Set WshShell = Nothing
    Yep, you must have hibernate disabled for the sleep shortcut to work as noted under Method Two.
  8. Posts : 207
    98SE/XP/windows7 ultimate 32bit
       #27
    thanks!
    just used it to my new win7 pc
    OPTION TWO
    Manually Create the Shortcut
    - works like charm
  9. Posts : 72,051
       #28
    You're most welcome prukeyhi. I'm glad it could help. :)
  10. Posts : 565
    Windows 7 Ultimate x32 With Sp1 + Vista Ultimate x32 with Sp1 & Sp2 !!
       #29
    Hi!
    Three things to mention & query :
    1. Sleep.vbs is taking my windows 8.1 x64 laptop to Shut Down even after setting the Power Button to Sleep. Hibernation is on But Hybrid Sleep is Off. Am I supposed to provide any images or reports ?
    2. There are better Icon options available for Sleep function at the address :
    %SystemRoot%\system32\SHELL32.dll
    3. I am using the '' PsShutdown -d -t 0 " command ( SysInternals Utility : PsTools / PsShutdown.exe ) for the shortcut. ( Ref : Microsoft Community Thread : 2nd Response )
    Is it a safe practice technically ?
    Thanks. ...
    UPDATE : Enjoyed! I had to Change Default Action of Alt+F4 "Shut Down Windows" Dialog to Sleep : EightForums i.e. the very same thing as the 4th Option ( Registry Option ) & 5th Option ( Group Policy ) as Change the Default Windows 7 Start Menu Power Button Action to Sleep!
    But Group Policy Registry is not available in windows 8!
