Backup User and System Files
Page 13 of 15 FirstFirst ... 31112131415 LastLast
  1. Posts : 6
    Thx! What I figured!
  2. Posts : 72,058
       #121
    You're most welcome. :)
  3. Posts : 37
    w7 Ultimate 32bit
       #122
    Considering that you just want to backup data files, docs, music, photos and .pst files:
    is it preferable (more practical) to use Backup facility, or just copy the relevant folders to an external disk?
    The Backup will only be usable by another W7 machine for a complete restore, or it can be used in the future as an ordinary folder (i.e. you can open it, see contents, copy/paste selectively etc.)?
    Sorry if this has already been answered; kindly point to the right post.
  4. Posts : 72,058
       #123
    Hello Abax,
    For just that, yes manually backing them up would be easier and more reliable. :)
  5. Posts : 37
    w7 Ultimate 32bit
       #124
    thnx Brink for answer.
    So, in this case what preferable use Backup would have (except system image)?
  6. whs
       #125
    I always put all my user files into a seperate data partition. Besides other advantages of such a setup, it also is easy to image that partition. I use free Macrium or Wbadmin for that.
    I also recommend to enable system restore points for the data partitions. If you happen to loose a file, you can also easily recover it with Shadow Explorer.
  7. Posts : 72,058
       #126
    It could be helpful if you wanted to create a backup of certain files and folders on a regular schedule to always have a updated backup automatically instead of doing it manually.
  8. Posts : 50
    Windows 7 Home Premiun 64bit
       #127
    Hi Shawn,
    I'm having dificulty with this.
    First let me tell you what I'm trying to do and what I have to do it with.
    I have two large hard drives and two DVD writers. One drive I store all my system files and software and the other is strictly for data.
    What I want to do is backup my data to a removable DVD-rewriteable disc.
    The first thing I did was format the disc. All went well. I set up the backup wizard to backup the data drive and set up the schedule. I then tried to perform the first backup. It started ok, but then told me to insert the DVD-RW in the drive. The disc was already in the drive. The only way I could get it to start was to push the tab "Insert Blank Media". It then started to perform the backup but quit at 67%. It's been backing up now for about 10 min. and shows 70%. What's wrong here?
    Also, is there a way to create a shortcut to perform a backup to this disc "on the fly"?
    Randy
  9. Posts : 72,058
       #128
    Hello Randy,
    To be honest using Windows Backup to a DVD is just not real reliable. Instead, I would recommend to either backup to another HDD/partition, or just manually copy and paste files that you wanted to backup to the DVDs/HDD/partition.
  10. Posts : 50
       #129
    Thanks. It finally completed the backup. I took a look at the files and I guess I completely misunderstood the concept. I thought it would simply write over the existing files in a simple fashion. Not so. It creates a plethora of files I have no idea what they are. You're idea will definitely work. I was looking for something that would be scheduled and simple. Not
