Backup User and System Files
Page 14 of 15 FirstFirst ... 412131415 LastLast
  1. Posts : 72,078
       #130
    That's good to hear. :)
  2. whs
       #131
    rwmol said:
    Thanks. It finally completed the backup. I took a look at the files and I guess I completely misunderstood the concept. I thought it would simply write over the existing files in a simple fashion. Not so. It creates a plethora of files I have no idea what they are. You're idea will definitely work. I was looking for something that would be scheduled and simple. Not
    If it were simple and straight forward, it would not be from Microsoft.
    But the real sad part is, if the recovery does not work as designed, then you cannot really do much with those files.
  3. Posts : 50
    Windows 7 Home Premiun 64bit
       #132
    Thanks everyone. I found a software utility that will do everything I want and more.
    Randy
  4. Posts : 28
    Win7 Pro SP1
       #133
    Has anyone had any issues with using a Samba share as your backup destination (including testing a restore from samba?)
  5. Posts : 205
    Windows 7 Home Premium
       #134
    Hi Shawn,
    I read in the article that ..Back up doesn't back up applications.. but when i back up .. its also saving exe files (ofcourse i like this).. so can I be sure that its always gonna save all my applications ?.. I want this cause I would want to back up all the programs that i downloaded from internet to my external hard disk ..via Windows backup.
    Thanks in Advance
  6. Posts : 72,078
       #135
    Hello nooruddin,
    Sorry for the confusion. Windows Backup will not backup or restore installed programs, but you will be able to back up the files in any folder(s) you include in the backup. Including any .exe files in them. :)
  7. Posts : 205
       #136
    Brink said:
    Hello nooruddin,
    Wow .. Great News :)
    Thanks Shawn..
    Also I Must Say .. Ur doing an Amazing Job .. Making other people's life lot easier .. Keep it up :)
    (i've read a lot of Ur tutuorials and v impressed)
  8. Posts : 72,078
       #137
    You're most welcome nooruddin, and thank you for the kind words. I'm glad that they can be helpful. :)
  9. Posts : 17
    Windows 10 Home 64-bit
       #138
    Hi everyone. Just have a question about using Windows 7 backup to do an incremental backup of a certain folder, after making a backup of that folder initially. Such as My Pictures etc. Is it easy to do? (Is it something that the program CAN do?)
    If not, what would be a good free alternative program to use to do this?
    Many thanks
  10. Posts : 72,078
       #139
    Hello ValiantSaint.
    If you set Windows Backup to automatically run on a schedule, then it'll keep the selected folder(s) backed up.
    You can also manually run the backup as needed or wanted as well. :)
